I was wondering if there is anyone that offers on-line searching of prior flight plans.
    $\begingroup$ Do you mean your own, or other's flight plans? $\endgroup$
    – J W
    Mar 29, 2016 at 0:21
  • $\begingroup$ My own would be just fine. $\endgroup$
    – Yogwhatup
    Mar 29, 2016 at 1:07
    $\begingroup$ Lockheed Martic Flight Service has a function to see your own past filed flight plans, though I have no experience with it. I would presume that it would only show you flight plans you filed through LMFS. $\endgroup$
    – J W
    Mar 29, 2016 at 1:14
  • $\begingroup$ I was looking for this function and was not able to find it a few days ago :( If anyone knows how to get to it, this should provide everything I need as all of my plans are created and put through LM. $\endgroup$
    – Yogwhatup
    Mar 29, 2016 at 20:20
Lockheed Martin Flight Services (LMFS) provides a history of filed flight plans on their web site under Flight Planning & Briefing | History. The path to the particular page is: https://www.1800wxbrief.com/Website/showPilotHistory.
Unfortunately, only the last 15 days are available. So if your flight plan is older, it won't be displayed. Additionally, if you're filing your flight plans through a service provider that doesn't provide full LMFS integration (e.g., ForeFlight) it won't be displayed even if within 15 days. In this case, you'll need to refer to your service provider's interface.
    $\begingroup$ Additionally, though this may not result in different data, LMSF offers a Recent Flight Plans drop down menu at the top left of the Briefings, Flight Plans, & NavLogs page, attempt at a direct link here. $\endgroup$
    – J W
    Mar 30, 2016 at 11:33
