11
I marked them with black circles. What are they for? enter image description here
Source (modified)
    $\begingroup$ in raft mode I'd guess a place for the tent to prop itself up with $\endgroup$ Mar 28, 2016 at 23:28
    $\begingroup$ Those are where the ladies hang their hand-bags on the way down. :) $\endgroup$
    – FreeMan
    Mar 29, 2016 at 17:40
11
@ratchet freak is correct. The protrusions are canopy poles, where the canopy in the evacuation slide/raft is propped up. The image below shows a canopy propped on them.
Canopy
Image from tulmar.com
From the document:
The canopy is supported in the center in 4 places by inflatable yellow “CANOPY END SUPPORTS” and “CANOPY CENTER SUPPORTS”, and supported along the sides by 14 numbered supports on the top of the slides inflatable structure.
Here's a closeup of the support from the same document.
Canopy support
    $\begingroup$ Has there ever been an actual event where a slide was required to be used in this way? $\endgroup$
    – woakley5
    Mar 29, 2016 at 3:57
    $\begingroup$ where is the actual canopy stored? $\endgroup$
    – Phantomazi
    Feb 8, 2017 at 23:11
