I noticed some dots and lines on the Boeing 747 engine pylons. What are they?
The above image is as seen in this video at 2:18.
Sign up to join this communityI noticed some dots and lines on the Boeing 747 engine pylons. What are they?
These are latches holding the engine support pylon panel in closed. Behind this panel is the diagonal brace.
This area was modified ~1992 due to the El Al Flight 1862 and China Airlines Flight 358 crashes.
See FAA Lessons Learned (via archive.is).
