What's the definition and the meaning of "soft dirt runway"? You can read that expression in the following text:
..The aircraft's rolling resistance, μ, is determined by the type of runway surface and by the type, number, inflation pressure and arrangement of the tires. A thin, high-pressure tire operated over a soft dirt runway will have so much rolling resistance that the aircraft may be unable to move. A large, low pressure tire can operate over a softer runway surface but will have more aerodynamic drag if not retracted, or will take up more room if retracted. Values of μ for different runway surfaces are provided in the detailed takeoff analysis in Chapter 17. ...
Source: Daniel P. Raymer, Aircraft design: a conceptual approach. Chapter 5 Thrust-to-weight ratio and wing loading, paragraph 5.3 Wing Loading, sub-paragraph Takeoff Distance, page 88.
