Is it possible to in-flight receive navigation data on an electronic device (like smartphone and/or tablet) present in the cockpit? I refer to General Aviation aircraft and navigation data like airspeed (not groundspeed), GPS and AHRS data.
$\begingroup$ Are you asking about when you're a passenger on an airline flight, or about using a smartphone or tablet in the cockpit? $\endgroup$– Dan HulmeMar 11, 2016 at 8:59
$\begingroup$ I didn't mean a passenger on an airline flight. I thought about the possibility of capturing data through smartphone or tablet in the cockpit (for instance with a wi-fi connection). $\endgroup$– sax631Mar 11, 2016 at 11:56
$\begingroup$ What kind of aircraft, then? It's going to depend a lot on the avionics already present. Please edit your question to add this information. $\endgroup$– Dan HulmeMar 11, 2016 at 12:52
$\begingroup$ There are several well-known options in the GA world, e.g. ForeFlight + Stratus 2 or Garmin Pilot + GDL39 will both give you everything you mentioned, including ADS-B in and AHRS. But they aren't substitutes for the aircraft's instruments (functionally or legally) and the navigation data and functionality may be limited depending on where you are in the world. $\endgroup$– PondlifeMar 11, 2016 at 14:07
$\begingroup$ @DanHulme - I've just reworded the question to specify I refer to GA aircraft. $\endgroup$– sax631Mar 11, 2016 at 14:23
Garmin has a product called Connext that allows you to stream in-flight avionics data to mobile devices. They are pushing that product as a move towards connected components and a "Bring your own device" approach to cockpit automation.
So is it possible in general to receive it? No, not really. Not unless the avionics package was designed to broadcast it out. As other answers have said, a simple GPS and AHRS integration of the sensors in your tablet/smartphone can give a pretty good approximation of the data you are asking for, but things like airspeed, navigation waypoints, and other on-board sensor data are not generally available without a product like Connext.
The other side of it is that if you are a passenger you still probably won't be able to pair with the avionics. Connext allows you to modify the flight plan via a mobile device, and I'm not sure I would want any of my passengers doing that. On top of that, pilots are trained to interpret the data at hand, you don't want a passenger seeing a faulty artificial horizon after a vacuum failure and think that the aircraft is tumbling out of the sky.
There is a lot of security concerns as it is over being able to hack into commercial aircraft (I know you are talking about GA), but I still don't want a passenger to have the ability to connect to my avionics.
4$\begingroup$ Does anyone find the phrase 'a "Bring your own device" approach to cockpit automation' incredibly scary? $\endgroup$ Mar 11, 2016 at 14:42
1$\begingroup$ For GA, no, for commercial, yes. I think its great for GA. For commercial I'd be surprised if it ever progresses beyond the EFB that a lot of airlines are now allowing instead of paper charts. The scary part is that in some incident reports the words "pilot was distracted by her iPad" has appeared... $\endgroup$ Mar 11, 2016 at 14:58
EDIT: This answer applies to large commercial aircraft.
As a normal passenger? No. As @mins said, this data is captured, processed, and displayed within the aircraft's avionics system, but this data is not available to passengers (it's not transmitted outside the avionics system).
When aircraft are being developed and the manufacturers perform flight tests, then they will install special gateways into the avionics, allowing the test engineers in flight and on the ground to monitor aircraft parameters outside the cockpit - but this equipment is removed long before aircraft are sold to an airline.
The best you can do is to use your own sensors - e.g. the GPS on your phone, a separate accelerator/gyro module - to generate your own position and attitude data. However, it will have a worse accuracy than the aircraft-level sensors, and there are certain parameters (e.g. airspeed) which you won't be able to obtain.
1$\begingroup$ The question has now been edited to focus on GA aircraft, though your answer still applies in general. $\endgroup$– fooot ♦Mar 11, 2016 at 15:29
Yes but only with certain avionics. Avidyne recently released an SDK that allows third party developers (tablet/smart phone) to interface with their IDF440 and 540 units. There are two levels of access (read only and read/write) that an app can have for the data stream.
