I always see images with a runway and a rectangular flight path over it and ask myself why do the pilots take off, fly around the runway and get back and land, what is the purpose of doing that: take off, fly parallel to the runway and land? Am I missing something? enter image description here
Source
  • $\begingroup$ It shows the different things that pilots can do in the pattern. Notwithstanding a student pilot in some part of his or her training will go around the pattern doing "touch and go"s. $\endgroup$ Mar 3, 2016 at 1:29
  • $\begingroup$ You might think of the traffic pattern as similar to an automobile round-about or traffic circle. $\endgroup$
    – J W
    Mar 3, 2016 at 13:44
10
I think there are two parts to your question: why do traffic patterns exist, and why do people fly around them in circles?
First, a huge amount of aviation effort goes into avoiding collisions, for obvious reasons. One part of that is making everyone behave as predictably as possible, so that you know what to expect from other pilots and where to look for aircraft near you. That's why there are regulations on airspace, altitudes, speeds and all sorts of other things that affect how and where aircraft fly: if everyone is following the same rules then life is much easier. For example, if you're driving down a one-way street in your car, you can be (reasonably) confident that you won't meet someone coming the other way, and drive accordingly.
Because aircraft operate very closely together around airports, there's a higher risk of collisions and it's especially important to have very clear rules for how and where pilots take off, approach the runway and land. The traffic pattern is the aviation equivalent of road markings: it 'shows' where you should fly in order to fit in with everyone else, fly in the same direction, be visible to others, and generally be as obvious and predictable as possible.
Second, why do pilots take off, fly around the pattern and land again? Usually, because it's a great training exercise. In the process of going around the pattern you have to perform multiple important maneuvers and tasks, including:
  • Taking off
  • Climbing out in a controlled, precise way
  • Making coordinated turns
  • Managing airspeed
  • Operating key aircraft systems like the landing gear, flaps, lights etc.
  • Using checklists
  • Working with ATC (if it's a controlled airport)
  • Descending in a controlled, stable approach to land
  • Landing
Since taking off and landing are often considered the riskiest parts of a flight, doing pattern work is a great way to get as much practice as quickly and easily as possible. For example, I just got back from doing some night pattern work: I did 10 takeoffs and landings in about 35 minutes. That packs a lot of practice into a short amount of time, which is useful for everyone but especially for student pilots.
    $\begingroup$ To improve your answer, mention that traffic circuit to a certain degree also exist for noise abatement reasons, at least where they are depicted on the Visual Approach Chart (here in Europe). Traffic circuits usually are away from housing areas and also provide obstacle clearance to a certain degree. $\endgroup$ Mar 3, 2016 at 6:46
    $\begingroup$ @SentryRaven From my perspective, I would not say that any standard rectangular traffic pattern—such as the one in question—exists for the purpose of noise abatement, though noise abatement is a consideration in determining whether the pattern is a right or left pattern; mine may be an FAA dependent perspective. However, I would also question whether charted visual approach terminal procedures fall within the scope of this question. $\endgroup$
    – J W
    Mar 3, 2016 at 13:38
    $\begingroup$ @SentryRaven That's a good point, although I tend to agree with JonathanWalters: noise abatement isn't really a consideration in a standard pattern layout, apart from sometimes using a right-hand pattern instead of a left-hand one. But it is certainly a reason for some non-standard patterns to be laid out the way they are. $\endgroup$
    – Pondlife
    Mar 3, 2016 at 18:17
  • $\begingroup$ Then this must be really an ICAO thing. Traffic circuits in Germany are influenced a lot by noise abatement. $\endgroup$ Mar 3, 2016 at 22:13
  • $\begingroup$ @SentryRaven Well, they don't sound "standard" then. :) $\endgroup$
    – Lnafziger
    Mar 5, 2016 at 17:44
