Is there a difference between overrun and overshoot landings or are they exactly the same, talking about a runway excursion?
  • $\begingroup$ Overrunning or overshooting a runway aren't in fact rynway excursions. A runway excursion means entering a runway without clearance and causing danger to other traffic. $\endgroup$
    – Sami
    Mar 1 '16 at 8:51
    $\begingroup$ @Sami: No, that's a runway incursion. $\endgroup$
    – Vikki
    Feb 22 '19 at 4:29
  • $\begingroup$ @Sean you're right. My bad. Second language problems 😕 $\endgroup$
    – Sami
    Feb 22 '19 at 8:58
They are more or less the same and are often used interchangeably. FAA AC 91-79 Runway Overrun Prevention defines runway overrun as:
A runway overrun event is a departure of the aircraft from the end of the intended landing runway surface.
It means that the aircraft has touched down on the runway before going off it. Overshoot is used in the same sense (note that overrun/overshoot occurs both in TO/landing).
However, there is one case where they are used differently. Overshooting the runway also can mean that the aircraft has touched beyond the end of the runway i.e. missed the runway entirely.
    $\begingroup$ Note that in Canada overshoot means go-around $\endgroup$
    – Pondlife
    Feb 29 '16 at 18:28
    $\begingroup$ Same in the UK. $\endgroup$ Feb 29 '16 at 19:18
    $\begingroup$ In the US Navy an overshoot meant flying through extended runway centerline during the approach turn, and having to come back for line up. (vs an angling approach) $\endgroup$ Mar 3 '20 at 23:57
