Almost every passenger cabin in a commercial aircraft is white with a little bit of grey. Why are they in these colors? Lufthansa737
Source
  • $\begingroup$ The orginally colour of plastic are nearly-white/colourless $\endgroup$
    – Him
    Feb 28, 2016 at 13:31
  • 20
    $\begingroup$ because sitting in a bright orange room for 8 hours would drive passengers insane. $\endgroup$ Feb 28, 2016 at 13:37
  • 8
    $\begingroup$ Why are the rooms in most houses painted white? Because it's a nice neutral color, and reflects light so you need less interior lighting. $\endgroup$
    – jamesqf
    Feb 28, 2016 at 19:54
    $\begingroup$ Check out this article on the innovative effects of colored lighting in the 787. The are also several videos on YouTube about it $\endgroup$
    – TomMcW
    Feb 28, 2016 at 21:43
    $\begingroup$ If you want to know the effect of lighting, just ask a picky lady about how her clothes/makeup looked just right at home, but are horrible now that she's out in the sunlight/office/night club. While fashion isn't the primary goal in cabin lighting, anything non-neutral will throw off perceptions which will range from moderate annoyance (colors don't look right in the in-flight magazine) to downright dangerous (finding the emergency exits in a red interior). $\endgroup$
    – FreeMan
    Feb 29, 2016 at 17:20
12
The picture in your question shows the answer: Most lighting in the cabin is done indirectly, so you don't see the light source directly. Instead, light is reflected off the cabin interior. If you would paint that interior in gaudy colors, you would have undesirable effects. Colored surfaces absorb some wavelengths, so the brightness in the cabin is reduced. Plus, the selective reflection will shift the color of the light.
  • Newspaper and magazine paper would not be white anymore, but have the color of the cabin interior. As @mins correctly points out, the brain can compensate for this. It will, however, make it difficult to read text printed in the color of the cabin interior because it would no longer stand out from the background.
  • The color pictures in the magazines would look funny. If you now think people could switch on the reading lights: Note how few passengers actually know how to operate them.
  • The food you get served would look funny. It is already not a pleasure to look at in most cases, but in colored light it gets even worse.
While it might be fun momentarily to be in a room with mood lighting, being exposed to this one color for the full length of the flight without a possibility to escape (except for closing your eyes) will offend most passengers.
    $\begingroup$ Just a detail: Actually our brain is able to do a "white balance" after some time without us being aware, so white paper will still be perceived as white. I don't know what is the color spectrum of our light at home, but it's probably no the same than mine, and it doesn't matter for color perception (if the spectrum is not too much degraded) This phenomenon creates visual artifacts of the complementary color when the object is removed, due to the previous "white balance". $\endgroup$
    – mins
    Feb 29, 2016 at 10:32
    $\begingroup$ +1 for "The food you get served would look funny. It is already not a pleasure to look at in most cases, but in colored light it gets even worse.." $\endgroup$
    – Santa
    Aug 18, 2016 at 13:17
Although not the original reason, modern plane interiors are designed to keep people calm. Boeing has a nice article on it here that is worth taking a look at.
Color psychology plays an important role in developing the overall look. Studies show that people in different cultures associate certain colors with similar emotions or concepts. Blue/green is nearly unanimously associated with peace. Pink and lavender shades connote love, while blue/purple may signify nobility.
The darker colors of seats can also aid in hiding stains and dirt better than say white or tan leather (which is found in a lot of GA planes).
As has also be mentioned in some of the comments white plastic is how most plastics are made thus its most likely cheaper to order something in white than have it colored.
There are some emergency implications to interior colors. In the case of an emergency you want the exits to be clearly marked and easy to find. If you have a "busy" interior when it comes to both over all design and color you can have issues making an emergency exit that contrasts well enough to see when it needs to be seen.
For what it's worth color has been tried (then again, it was the 70s). Now think about a red emergency light going off in this plane, it would barely stand out. enter image description here (source)
  • 9
    $\begingroup$ Are you sure this is a picture from an actual plane? Looks like the Village People are about to start singing... :-) $\endgroup$
    – jcaron
    Feb 29, 2016 at 0:00
    $\begingroup$ @jcaron That is Braniff International Airways $\endgroup$
    – Him
    Feb 29, 2016 at 1:01
    $\begingroup$ I love the cabin crew uniform. $\endgroup$
    – user19474
    Feb 29, 2016 at 17:35
    $\begingroup$ The 60s were a bit different... $\endgroup$
    – FreeMan
    Feb 29, 2016 at 18:17
