Aircraft use GPS and inertial navigation systems in combination. Sometimes INS needs alignment (i.e. to be told where it is AND what orientation it has). How can an aircraft be be aligned to true north for proper INS alignment? Are markings at the parking location good enough?
1 Answer
A small 0.5° error in assumed heading translates into 10 NM error in computed position on the distance Madrid-Montreal (3,000 NM). As many other errors must be taken into account, north must be known to a higher degree to achieve this accuracy, and a better accuracy is also expected This cannot be done using simple markings.
But true north is related to Earth spin axis, which can be accurately sensed by an INS using a gyroscope.
Inertial systems belong to two families: platform and strapdown:
In platform INS (PINS) accelerometers and gyros are mounted on a gimballed platform kept level and oriented to north by torque motors driven by gyros outputs.
In strapdown INS (SINS) these sensors are firmly fixed on the aircraft.
PINS are mostly using momentum wheels. Recent gyros are SINS and not inertia-based, they usually measure length differences created by Sagnac effect (fiber optic, ring laser, acoustic...):
Ring laser gyros in AN/WSN-7 US Navy navigation system (source)
Regardless of the type, alignment is similar and consists in sensing Earth spin axis and gravity, and is twofold: Leveling, then gyrocompassing.
Alignment principle
Accelerometers and gyroscopes arrangement in an inertial system, and final orientation:
Leveling
Axes which in the end will point to north and east are in a first step leveled by tilting the assembly. Leveling solely involves accelerometers and gravity.
Leveling is real for PINS, it gives the platform its working orientation, found by zeroing north and east accelerometer outputs while the unit is stationary. After alignment, accelerometers are able to directly sense accelerations along north, east and up directions.
Leveling is virtual (software) for SINS. It consists in evaluating the initial orientation to build a transformation matrix. This matrix is used for projecting the values issued by tilted sensors onto a virtual level platform. The matrix is then constantly updated with orientation changes detected by gyros.
Gyrocompassing
Likewise leveling, gyrocompassing is real or virtual according to the type of inertial system. Gyrocompassing goal is to determine true north using gyros.
After leveling, for a stationary aircraft, north and east gyros (designated X and Y below) sense only Earth rotation, in quantities depending on their orientation relative to Earth spin axis:
- On the left hand picture, X gyro fully senses Earth rotation effects as it is aligned with spin axis, Y gyro doesn't detect any rotation.
- On the middle picture, the system has been rotated by 90°, the result is reversed.
- The right hand picture depicts the general case: Both gyros detect Earth rotation rate, but in quantities depending on the heading. X detects a rate proportional to the cosine of the heading, Y a rate proportional to the sine.
Finding north is done by rotating (virtual rotation for SINS) the leveled assembly about the vertical axis until the east gyro output is null, meaning its axis points to east or west. This ambiguity is removed by sensing rotation direction on the other axis which now points north or south.
Earth rate detection depends on (cosine of the) latitude angle:
Earth rotation rate sensing by an inertial system versus latitude
Merging what we exposed above, the sensed rates Rx and Ry are given by:
$$ \begin {cases} Rx & = & \omega \times \cos \alpha \cos \phi \\ Ry & = & \omega \times \sin \alpha \cos \phi \end {cases}$$
- $\omega$ is the constant for Earth spin rate, $\approx 15$°/hour (360° in a sidereal day),
- $\phi$ is the latitude,
- $\alpha$ is the heading of the aircraft (or of the reference axis).
With two linear equations for two unknowns, finding latitude and heading is straight forward, the only condition is Rx and Ry are known. That is where the shoe pinches. Gyrocompassing is actually difficult and slow.
Actual application of the principle is challenging
While the principle is simple, it's difficult to measure Rx and Ry. The reason is $\omega$ is tiny (0.004°/s), measures must be repeated during a significant time. Five minutes is sufficient at the equator, but twenty minutes are not unusual at 45° latitude.
The pilot can provide the current approximated latitude to allow this process to converge more quickly.
Boeing 737, FMS page used to enter the initial position estimate to speed up gyrocompassing
Sensor fusion, alignment in motion and loss of alignment
Alignment may be facilitated, and subsequent measures can be improved by associating additional sources of data, and merging sources after filtering excessive divergence, this is known as sensor fusion and IRS/GNSS hybridization. These sources include GNSS (position and Doppler velocity), magnetometers, air data, even Doppler velocities of known targets but that's more for underwater rovs to replace GNSS.
The different sources allow to maintain the natural cumulated drift associated with the integration process, which is central to inertial positioning, below some threshold, e.g. thresholds fixed by required navigation performance procedures.
In some conditions the inertial system can even be realigned in flight from GNSS position and Doppler velocity (e.g. Northrop Grumman LCR-110). Such in-flight alignment should be common in the future.
Level and north orientation are kept after alignment by adjusting the orientation and compensating detected aircraft orientation changes. The sidereal alignment is therefore not maintained.
Most inertial systems cannot be realigned in motion, but they can be re-leveled, and while the north direction and the position cannot be recovered, the system is still be able to provide aircraft attitude (mode ATT).
The two IRS switches in the normal (navigation) position (source)
$\begingroup$ The acceleration due to Earth rotation can't be told apart from that due to gravity. However, the rotation itself can, since the gyroscopes will maintain fixed plane of rotation relative to universe. $\endgroup$ Feb 28, 2016 at 14:10
$\begingroup$ @JanHudec: I simplified my post and included your feedback. Thanks. $\endgroup$– minsFeb 28, 2016 at 17:41
$\begingroup$ Firstly GPS gives position but NOT orientation, hence not true north or any other orientation information. I have since read confirming my understanding that a LINS on the ground by detecting gravity and earth rotation can determine latitude and true north by itself, (Though not longitude.) To speed up alignment it is best to park a/c at a known position at aerodrome with known orientation marked with parking position and north. How does person who paints on the parking position coordinates AND direction to north. Does he/she use the stars? $\endgroup$ Feb 29, 2016 at 20:04
$\begingroup$ @CahalCormican: GPS doesn't provide north indication, it's calculated by inertial: right. North is entered based on ramp markings: wrong, it's not necessary. Ramp coordinates are determined using differential GPS surveying and then loaded into the FMS database by database updates each 28 days. The precision of the D-GPS is about 10 cm, but can be improved further with longer integration time, when required. There is not survey based on stars, it is not precise enough, it can used by spacecraft remote from the GPS constellation. $\endgroup$– minsFeb 29, 2016 at 22:19
$\begingroup$ This all sounded true and informative until this statement "The inertial system can determine the latitude by sensing local acceleration, but not the longitude. Longitude is provided, usually by the pilot. Latitude is provided as well at the same time." which is contradictory to what you wrote in the beginning "The pilot will just provide the current latitude to allow this process to work accurately". $\endgroup$– Craig KMar 1, 2016 at 2:11
