The short version is that yes, larger aircraft create bigger sonic booms, but you still have to be flying very low (less than 100 ft.) and really trying hard in order to damage glass.
A sonic boom is so complicated that you will not find a simple formula to determine the strength. This article describes a modeling tool called PCBoom3 which can be used for sonic boom calculations.
According to several different sites, like this one and this one, the size of the aircraft does affect the intensity:
Factors Affecting Sonic Boom Intensity
The intensity of sonic booms are affected by:
- Weight, size and shape of the aircraft.
- Altitude
- Attitude—orientation of the aircraft’s axes relative to the its direction of motion.
- Flight path.
- Atmospheric and weather conditions.
As the size and weight of the aircraft increases, the intensity of the
sonic increases. This is because a larger aircraft displaces more air,
and a heavier aircraft needs a greater force of lift to sustain
flight. Thus creating a louder and stronger sonic boom.
and
General Factors Associated With Sonic Booms
There are several factors
that can influence sonic booms -- weight, size, and shape of the
aircraft or vehicle, plus its altitude, attitude and flight path, and
weather or atmospheric conditions.
A larger and heavier aircraft must displace more air and create more
lift to sustain flight, compared with small, light aircraft.
Therefore, they will create sonic booms stronger and louder than those
of smaller, lighter aircraft. The larger and heavier the aircraft, the
stronger the shock waves will be.
NASA says that a typical sonic boom for the F/A-18 is about 1.4 psf and a different NASA page goes on to say:
Overpressure Sonic booms are measured in pounds per square foot of
overpressure. This is the amount of the increase over the normal
atmospheric pressure which surrounds us (2,116 psf/14.7 psi). At one
pound overpressure, no damage to structures would be expected.
Overpressures of 1 to 2 pounds are produced by supersonic aircraft
flying at normal operating altitudes. Some public reaction could be
expected between 1.5 and 2 lb. Rare minor damage may occur with 2 to
5 lb overpressure.
As overpressure increases, the likelihood of structural damage and
stronger public reaction also increases. Tests, however, have shown
that structures in good condition have been undamaged by overpressures
of up to 11 lb. Sonic booms produced by aircraft flying supersonic at
altitudes of less than 100 feet, creating between 20 and 144 lb
overpressure, have been experienced by humans without injury.
Damage to eardrums can be expected when overpressures reach 720 lb.
Overpressures of 2160 lb would have to be generated to produce lung
damage.
Typical overpressure of aircraft types are:
- SR-71: 0.9 lb, speed of Mach 3, 80,000 feet
- Concorde SST: 1.94 lb, speed of Mach 2, 52,000 feet
- F-104: 0.8 lb, speed of Mach 1.93, 48,000 feet
- Space Shuttle: 1.25 lb, speed of Mach 1.5, 60,000 feet, landing approach
They also include a graphic that shows the difference in sonic boom between the F-18 and the Concorde, with the Concorde having a much greater sonic boom at the same alittude:
This article specifically covers glass:
Glass. Poorly mounted, undamaged glass in the greenhouse was chipped
by impact against nail holding points at a sonic boom overpressure of
12.1 psf. The same type of glass, which was already damaged, was further damaged at a designed overpressure of 7.9 psf. A large
one-ninth of an inch thick window, intentionally precracked from
corner to corner, was further damaged by booms of an average 6.5 psf
overpressure.
So typical sonic booms generated by normal aircraft aren't going to create anywhere close to the 12.1 psf that they say is needed to chip "poorly mounted" glass, but the strongest sonic booms can get well over this.
The strongest sonic boom ever recorded was 7,000 Pa (144 psf) and it did not cause injury to the researchers who were exposed to it. The boom was produced by an F-4 flying just above the speed of sound at an altitude of 100 feet (30 m)
$\endgroup$ – SSumner Mar 22 '14 at 1:24
