I don't see it has covers for the flap tracks, so,where are the covers for the flap tracks?
wing
Image taken from the English for Aviation book (Oxford).
The aircraft is a Vickers VC10
    $\begingroup$ It appears the shock bodies aren't being used for the flap tracks, as the flaps are only between them and not over them. So there is nothing to cover. $\endgroup$
    – fooot
    Feb 20, 2016 at 22:25
  • $\begingroup$ But wouldn't that result in drag? $\endgroup$
    – user13197
    Feb 20, 2016 at 22:27
  • $\begingroup$ the shock bodies will increase the wet surface and the friction drag but they reduce the wave drag, netly is interesting to include them $\endgroup$ Feb 20, 2016 at 22:36
  • $\begingroup$ So the flap tracks are uncovered, that means the wing will have drag? Is it inefficient to have flap tracks uncovered? $\endgroup$
    – user13197
    Feb 20, 2016 at 22:41
    $\begingroup$ Well yes, if they are not faired, they will add drag... but if we're talking about the pictured wing, we can't see the flap tracks so we don't know how much. $\endgroup$
    – fooot
    Feb 20, 2016 at 22:58
From the Vickers VC-10 repair manual:
General arrangement of VC-10 wing
General arrangement of VC-10 wing (picture source). Note the labelling of the Shock bodies as "flap rail fairings".
The flap tracks were inside the Küchemann bodies and the flaps were between them. This produced gaps between the five flap segments which made them less effective than the modern design of uninterrupted flaps with the flap tracks below them.
They look like Fowler flaps, like on Hercules c130. If that's the case the flaps run on screwjacks and rollers and slip up and into the wing when cursing. All the mechinisums are shrouded by the flaps themselves when retracted and hence no drag. On takeoff and landing the drag is overcome by takeoff thrust and on landing augmented by airbrakes to reduce landing speed. The flap tracks are in the wing and accessable only when the flaps are extended/ deployed.
    $\begingroup$ Gotta love "cursing" around in an airplane! $\endgroup$
    – Ralph J
    Feb 21, 2016 at 0:31
