Reading "Long Range Aircraft-AEA Requirements".
In appendix, Para 1.2 "Definitions and specifications", the definition for "Stage Length" states
Stage length [...] for payload calculations includes 85% wind.
What does that mean?
The document AEA Requirements Long Range Aircraft is related to airline fleet planning, and the calculation of the fuel needs. Note that it is dated Dec. 1987. More on airline fleet planning.
85% wind
For this planning the document from the airlines association recommends to assume the wind that has a probability to occur of 85%. That means: assume you will find this wind on your route 85% of the time. The wind force itself is determined talking into account statistics for the regions overflown.
Stage
The flight profile is provided on the document itself, defining "stage" as start of climb to end of descent, excluding initial climb:
Planning profitability
Knowing how much fuel will be required and by deduction how much payload can be transported allow airlines to estimate the airline costs and revenues on a given route with a given aircraft. This is important for planning aircraft acquisition and replacement, as well as the route catalog.
Stage length is basically the average length of the flight (see mins' answer for a specific definition). Average stage length is important because it greatly effects the maintenance and fuel costs for the airplane. The shorter the stage length, the higher your overall costs will be for the operation of the airplane (and vice-versa, of course).
In order to estimate the stage length, the following information is needed:
  • Routes which will be flown
  • Performance information for the aircraft
  • Average winds which will be encountered during the flights
The 85% most likely refers to the Boeing 85% wind data, which is proprietary data produced and sold by Boeing and includes world-wide wind and temperature data at various flight levels and seasons, with statistical reliability between 50% and 99%.
This means that the wind values which are used for the stage length calculation will result in a flight time equal to or better than the result 85% of the time.
