Some airports have a non-standard traffic pattern altitude. For example KGXY is 800 feet. Why is this?
Airports underneath controlled airspace may need to keep their traffic clear of controlled airspace, which may start from a typical altitude such as 1000Ft.
As is also mentioned in this answer, in April 2013 the standard pattern height was changed from 800 ft to 1000ft, possibly accounting for a number of airports still having the old "standard".
$\begingroup$ Many airports have non-standard traffic pattern altitudes (lower, in my experience) that are not due to airspace considerations. For example, KACQ has a TPA of 800 AGL, despite Class E starting at 700 above the airfield and continuing up to the floor of A. $\endgroup$ – J Walters Feb 11 '16 at 16:06
1$\begingroup$ I just talked to the airport manager at ACQ, and he says he has no idea, just the way it is. "Some airports have 800 foot patterns, some 1000." $\endgroup$ – J Walters Feb 11 '16 at 17:08
1$\begingroup$ @JonathanWalters, this answer mentions the default used to be 800 and then it was changed to 1000. $\endgroup$ – Jan Hudec Feb 11 '16 at 22:07
