In the IATA Airport Handling Manual procedures, messages are send to communicate with the transit station to describe the cargo load. The Load message LDM (AHM 583) is sent primarily to enable the transit station to know in advance the load which continues on the same aircraft.
LDM ZZ999/13.ZZOEA.Y136.2/4
-SHJ.15/22/3/1.T1500.3/1000.4/500.PAX/40.PAD/0
-CMB.27/22/12/3.T3500.1/2800.5/700.PAX/61.PAD/0 SI
In here we got hold id 3 total gross weight 1000kg,... In our automated system, we need info in compartment bay level.
How can we get those information?
- Any other message like Container / Pallet Distribution Message CPM (AHM 587)?
- Or we have to manage manually (should distribute by load controller)
edit
link. You should still explain the context: Are you a developer or a user? Are you using an application or an API? Which one? $\endgroup$ – mins Feb 12 '16 at 10:18
