12
The A320 doesn't have a dorsal fin, but the 737 does. If the 737 is more or less a similar aircraft, why doesn't the A320 have a similar dorsal fin?
By Bill Larkins [CC BY-SA 2.0], via Wikimedia Commons
    $\begingroup$ In general, see dorsals and strakes $\endgroup$
    – fooot
    Feb 10, 2016 at 18:19
5 Answers 5
15
Boeing learned the value of a dorsal strake the hard way: On their civilian version of the B-17, the Boeing 307 Stratoliner, the first Boeing aircraft with a pressurized cabin, the lack of a strake ahead of the fin caused the rudder to lock in the hard-over position when the pilot demonstrated the capability of the aircraft to fly with two dead engines on one side. The aircraft entered a spin and crashed, and that was on a demonstration flight for prospective customers.
Early Boeing 307 with the two right engines off and props feathered
Early Boeing 307 with the two right engines off and props feathered (picture source). Note the deflected rudder and the rectangular windows in a pressurized fuselage. It worked because the pressure difference was small.
Late Boeing 307 in flight
Late Boeing 307 in flight (picture source). The vertical was enlarged and had the strake added; the same vertical was also used on later versions of the B-17.
With today's hydraulically operated controls the risk of an uncontrollable hard-over is reduced, but exactly this happened to several early Boeing 737s. From the 737-300 on the strake was added and the control system (PCU = power control unit) was exchanged for a modified version.
Airbus never had those issues and did not see the need to add a strake since the existing vertical could do its job in all conditions. A strake is worthless at small sideslip angles and will only help when the vertical is close to stalling due to extreme sideslip. Adding a strake will increase the wetted surface area and add friction drag, so Airbus did not include one.
    $\begingroup$ One of the rudder hardovers was a -200 but the other was a -300 which already had the strake. $\endgroup$
    – fooot
    Feb 10, 2016 at 22:09
    $\begingroup$ @PeterKämpf Why did the lack of a strake cause the rudder hardover? I'm having trouble connecting the two $\endgroup$
    – Kxy
    Aug 27, 2017 at 21:06
    $\begingroup$ It just indicates a cleaner design on Airbus' part. Dorsal strakes, wing fences, vortex generators etc are just bandaids for poor airplane design. $\endgroup$ Aug 28, 2017 at 1:09
    $\begingroup$ @Ksery: Now I understand, you were not referring to the 737 but the 307. Yes, I did. This happened on the Boeing 307, and I have witnessed the same on other, smaller airplanes where control forces were still manageable with a hard-over rudder. The rudder will stall at an earlier sideslip angle and the suction of the separated flow will cause the hard over rudder. Adding a strake will cause a vortex which will mix the flow on the leeward side so the separation does not occur as early. See here for vortex lift $\endgroup$ Aug 28, 2017 at 14:12
    $\begingroup$ @PeterKämpf Thanks for the clarification, and wow, that is quite a scary phenomenon $\endgroup$
    – Kxy
    Aug 28, 2017 at 14:32
Adding to PK's very informative answer:
The 737 Original series did not have this dorsal fin. When the newer series was introduced (737 Classic) with the new 1.6x more powerful engines, the dorsal fin was needed "to cope with greater asymmetric thrust potential."
Source: Flight, (1982).
The design remained with the 737NG and 737 MAX to keep the cost down: machining, suppliers, R&D, testing, etc.
Adding a dorsal fin, increases surface area. The plus theoretical side is that it increases directional stability. The minus theoretical side is that it adds weight, drag, and manufacturing complexity.
Early 737s did not have a dorsal fin. Presumably, at some point Boeing decided that adding one would provide better performance.
Airbus apparently does not see the need for on in the A320.
They are all design decisions.
    $\begingroup$ not performance but safety is improved. If you have a bad record it pays to go to some extra effort. $\endgroup$ Feb 10, 2016 at 21:21
    $\begingroup$ With due respect, I don't see how this post can be an answer to the question, it's mostly speculation (theoretical, presumably, apparently, ...), references are needed. There is a much better alternative. $\endgroup$
    – mins
    Feb 10, 2016 at 22:30
In addition to ymb1's answer, I found this video of a B737 Pilot that specifically explains why is added in new models.
The short answer is very similar to that already provided, but explained in details and with some examples, maybe could result easier for someone to figure out reasons.
Boeing had two options "to cope with greater asymmetric thrust potential" increase tail height or enlarge its surface horizontally, but existing customers preferred second option because they already had hangars designed for previous B737 series with not enough height.
Continuing comparison to A320 family, we can also say that in A318 (the shortest of the family), Airbus too needed to enlarge tail surface (increasing its height in this case) because shorter fuselage caused less torque that should be compensated by additional force at the end.
For those that are more technicians, physical explanation could be the following:
Since the torque on a body is defined as T=F x d, where "F" is the applied force at a point P of the body, "d" is the distance from P to the center of the rotation and "x" is the cross product, it's clear that by reducing d we need to proportionally increase F to keep T constant
    $\begingroup$ The extreme examples are the A300-600ST Beluga and the new A330 Beluga XL vs the normal versions. $\endgroup$
    – user71659
    Jan 16, 2019 at 0:24
Note in your photos that the A320's tail in general is wider than the 737's.
So it can be argued that Airbus met the same need with a different tail design. They didn't use a strake, they made the whole vertical stabilizer larger.
The fact that the 737 was originally designed in the 1960's for turbojet engines, while the A320 was designed in the late 1980's with the more powerful turbofan engines, may be the reason that Airbus made the whole vertical stabilizer wider.
  • $\begingroup$ The 737 was originally designed in the 1960s to use the JT8D turbofan, not a turbojet. The change that happened in the 1980s for narrowbody jetliners was from low-bypass to high-bypass turbofans; the change from turbojets to turbofans occurred in the early 1960s. $\endgroup$
    – Vikki
    May 11, 2019 at 21:50
