17
I was flying from Heathrow to Miami last wednesday (AA 39) and for the first ⅔ of the flight we were flying at 28.000 feet, only afterwards did it go up to 33.000 feet. So far I was under the impression that for reasons of fuel efficiency, airliners would try to fly as high as possible, and looking at the same flight on different days, it seems like they do in fact usually fly higher. So what could have been the reason for such a low altitude? Was it just weight due to being fully loaded, or are there other reasons as well?
  • $\begingroup$ Weight shouldn't be a factor; you were on a 777-300ER, and would have had plenty of engine power to maintain whatever altitude you wanted. $\endgroup$
    – Timpanus
    Feb 7, 2016 at 16:36
25
Looking at the route your plane took, this low altitude flight was likely to avoid the polar jetstream. This is a band of wind that blows west to east in roughly the area the first half of your flight was flying through. It exists mostly between 30,000 and 39,000 feet altitude, and can range from about 60mph to over 200mph. I suspect that the low altitude was to keep the plane below this jetstream, avoiding the headwind and fuel and time costs that flying through it would create. To answer the other part of your question, as I mentioned in the comments, weight shouldn't have been an issue because the plane you were in (a 777-300ER), has more than enough engine power to maintain a higher altitude, even fully weighted.
    $\begingroup$ It's actually worth looking at the reverse flight times for routes like this. Most trans-(North) Atlantic routes are on average about an hour shorter going East->West versus West->East for exactly this reason. East->West uses as much wind as practical to gain efficiency but West->East this turns into a penalty and flights try to avoid as much wind as possible. There's a reason European explorers landed in the carribbean on the first go around all those years ago, then had to tack north to catch the westerlies home. $\endgroup$
    – J...
    Feb 8, 2016 at 12:48
    $\begingroup$ Relevant for visualization : Global Wind Map $\endgroup$
    – J...
    Feb 8, 2016 at 12:54
12
There are generally 3 reasons to pick lower altitudes:
  1. At departure your weight would be too much to climb to the desired altitude. Some aircraft are restricted by weight to get up to higher altitudes, usually a thrust-weight issue.
  2. Something's broken on the aircraft requiring it to fly at a lower altitude for safety reasons. As an example, the Air conditioning packs, that control the pressurization on an aircraft, if one is out, the flight might be restricted to a lower altitude so the system can handle the reduced output of the remaining packs to maintain a suitable pressure onboard.
  3. The most likely reason though in this case is to be at an altidude where the headwinds are less than what they are higher. Oftentimes the highest winds in the jetstream start in the FL300+ range, and run generally West-East. So trying to pick an optimal altitude is a factor of getting high enough for efficiency, but not to where you'll be losing that efficiency due to the higher winds aloft.
  • $\begingroup$ Why would the plane even be flying with a busted a/c pack though? On all the flights I've been on, pretty much any mechanical issue has led to the problem either being addressed in the ground or a new plane being used. I've almost never been on a flight that was allowed to take off with a mechanical issue. $\endgroup$
    – Timpanus
    Feb 7, 2016 at 16:58
  • 13
    $\begingroup$ @Timpanus It's not that simple. I would be surprised if any flight you have been on did not have a mechanical issue. $\endgroup$
    – Simon
    Feb 7, 2016 at 17:32
  • $\begingroup$ I doubt #1 is true in this case, the 777 practically has enough power to tow another 777 up to cruise altitude, and #2 makes little sense since the flight later climbed higher. #3 is very plausible, though $\endgroup$
    – Jon Story
    Feb 8, 2016 at 11:46
    $\begingroup$ @JonStory That would be an awesome experiment to see. $\endgroup$
    – Jens
    Feb 8, 2016 at 11:54
    $\begingroup$ haha, I did say "practically" - my point was really that I don't believe a 777 even at MTOW will struggle to climb pretty much straight to FL310/330 (notwithstanding a few steps in the climb to increase airspeed) $\endgroup$
    – Jon Story
    Feb 8, 2016 at 12:00
They could also have over filled the tank. I'm on an AA flight right now that's choosing to fly lower to burn more fuel.
    $\begingroup$ Unless they're at risk of landing overweight, I can't imagine that they'd be burning money, er... fuel just because the ground crew put in too much. Unless, of course, you've had an announcement telling you so. $\endgroup$
    – FreeMan
    Feb 27 at 19:45
    $\begingroup$ Your answer could be improved with additional supporting information. Please edit to add further details, such as citations or documentation, so that others can confirm that your answer is correct. You can find more information on how to write good answers in the help center. $\endgroup$
    – Community Bot
    Feb 27 at 20:58
