16
I understand that tailwind is typically a good thing during your flight as it increases your ground speed and gets you to your destination faster. Despite that I get a feeling that pilots typically get very uncomfortable when there is a significant tailwind present during landing. Sadly, recent proof of this danger was in Aspen, Colorado accident
Questions:
  1. Why are tailwinds bad during landing?
  2. Given "extra long" runway for extended rollout, are there any dangers with landing at a higher ground speed?
  3. How are tailwinds mitigated? Would ATC just switch the landing direction?
It's not so much a matter of "pilots typically get very uncomfortable" as it is "pilots recognize that it is an inherently less safe situation", and pilots (at least the ones you want to fly with) tend to be somewhat safety obsessed.
So Why are tailwinds during landing "bad"?
The same reason tailwinds in cruise flight are good: you're moving over the ground at a higher speed.
The amount of energy the aircraft has (and thus its landing distance) is roughly proportional to the square of the groundspeed.
Let's consider the plane I fly as an example (a Piper Cherokee) because I know the numbers:
if I'm flying by the book then when the wheels of my plane hit the ground my indicated airspeed should be around 45 knots.
  • No Wind
    If there's no wind my ground speed and my indicated airspeed will be about the same - my brakes will have to slow me from 45 knots to a stop before I run out of runway.
    The brakes on the Cherokee aren't Porsche brakes (they're tiny little things), but they're up to the task and a book-perfect landing would have me stopped in 600 feet.
  • 15-Knot Headwind
    A 15 knot headwind reduces my groundspeed to 30 knots - at 2/3 the speed I can stop much sooner with the same braking force, which means less wear on the brakes and a greater safety margin of runway remaining.
    A book-perfect landing in these conditions would have me stopped in about 270 feet.
  • 15-knot Tailwind
    A 15 knot tailwind increases my groundspeed to 60 knots. The tiny little brakes on the Cherokee CAN stop me, but they're going to take much longer to do so: A book-perfect landing would take over 1000 feet to stop (nearly twice the "normal" no-wind landing roll).
The big consideration above is landing distance -- as you noted in your question you can solve that with a longer runway (more pavement means more room to stop), but there are other dangers with tailwind landings, mainly in the fact that Landings don't always go according to plan.
The slower your groundspeed at landing the less energy you have to get rid of if something goes wrong
Consider the three landings I outlined above, but let's add a problem to the mix: One of my tires blows right at touchdown, and the plane veers off the runway into a ditch.
There is much less energy to dissipate with a 15-knot headwind (30kt groundspeed) than there is with a 15-knot tailwind (60kt groundspeed) - it's roughly the difference between crashing your car driving through a school zone versus speeding on a highway.
Fortunately it's really easy to avoid landing with a tailwind -- most runways are bidirectional (Aspen, which you mentioned in your question, is a notable exception due to geography).
ATC (or at uncontrolled fields, the pilots themselves) will "turn the airport around" once a certain tailwind limit is reached. Precisely when that happens depends on the airport and the traffic mix (at my home field, with mostly small piston aircraft, ATC will typically switch the runway when the tailwind component exceeds 5 knots - at JFK they might land a jet with a 10-knot tailwind rather than messing up the arrivals).
Of course there's nothing that says a pilot has to accept a landing with a tailwind: If the pilot is not comfortable with the conditions they can request a runway aligned so the winds are more favorable. (There is a somewhat famous case of an airline pilot at JFK who ultimately decided to declare an emergency to ensure a landing on a favorable runway).
    $\begingroup$ Actually you can land either direction at Aspen, but you get pretty close to the terrain and they avoid it if possible. $\endgroup$ – Lnafziger Mar 20 '14 at 18:25
    $\begingroup$ Also, I was going to add an answer later but this one hits most of my points. I would add one further thing though: A tailwind will decrease control surface effectiveness more quickly than without one while you are still traveling faster. This is particularly an issue with tailwheel aircraft, but it does affect all of them! $\endgroup$ – Lnafziger Mar 20 '14 at 18:26
    $\begingroup$ Also remember that the amount of energy that needs to be dissipated increases with the square of the speed. To stop from 80kts takes 4 times the effort as to stop from 40kts. $\endgroup$ – Simon Mar 20 '14 at 19:24
    $\begingroup$ @voretaq7, nice answer. The physics makes sense. And yeah I have heard of that JFK pilot, very ballsy! $\endgroup$ – KORD4me Mar 20 '14 at 22:34
    $\begingroup$ One other thing that can be a consideration in larger aircraft is the brake energy limit. Higher ground speeds may make you exceed it. Oh, and you can also run up against your maximum tire speed as well! $\endgroup$ – Lnafziger Apr 2 '14 at 5:33
11
The primary concern is the increased landing distance due to the increased ground speed. Landing & stopping distances increase more-than-linerally with each knot increase in ground speed. Given other dynamics of a landing aircraft this can be the straw that breaks the camel's back.
The perfect storm
True story. C-141 on approach with a tail wind - not so bad by itself. Add in a 7,000-ish foot runway and indicated airspeed a little high.
  1. The aircraft didn't want to land so to speak because of the increased lift due to excessive indicated airspeed. Also any gust (differential) is added to approach speed. In other words, the plane could not get into a landing attitude due to excess lift.
  2. Flying over the ground even faster due to 1, above, and the tailwind induced ground speed increase.
  3. Pilot realizes he's floating too much and pushes down to get the plane on the ground.
  4. Nose wheel touches down - but not the mains! Pilots don't realize this.
  5. Pilot applies brakes and nothing happens, the mains still in the air and all. Panic begins.
  6. The end of the runway is getting closer and the pilot aggressively applies the brakes.
  7. The mains touch down and tires immediately begin to blow out, due the locked brakes.
  8. The aircraft is departing center line due to tires blown out on one side.
  9. Pilot struggles to maintain control as the aircraft nears the end of the runway.
  10. Still too fast for safe taxiing, pilot attempts to turn the aircraft onto the last taxi way before the end of the runway.
  11. Aircraft nose is turning but momentum, excess speed, drag from blown tires, differential braking - plane now slides sideways.
  12. Aircraft stops just off of the end of the runway facing 90 degrees.
  13. Aircraft catches on fire. That it's on the side of the blown tires and dragging strut is no surprise.
  14. Everyone gets out safely.
  15. NOTAM issued warning aircraft to beware the burned out hulk at the end of the runway. Adjust TakeOff and Landing Data accordingly.
And the worst part of all of this?
  1. It was to be the aircraft commander's "fini flight" - his last (multi stop) mission before leaving the Air Force. And so it was, only more so.
  • $\begingroup$ What did the aircraft catch on fire from? Did one of the wingtips hit the ground while it was sliding? $\endgroup$ – Vikki - formerly Sean Feb 12 '19 at 4:27
  • $\begingroup$ The heat from locked brakes, shredding heated tires, gear strut disintegrating. The aircraft did not break apart. I believe confined pretty much around that wheel well and wing root. The plane was not burned to the ground and the wings were in in tact. I got only a couple of seconds to glance down as we flew over it. $\endgroup$ – radarbob Feb 13 '19 at 9:30
As others have highlighted, the question is with what ground speed you touch down. You might think that plus/minus a few knots doesn't really matter, but:
  • your kinetic energy is quadratic in speed: E = 1/2 m v^2.
  • if braking acceleration is constant, landing distance is quadratic in speed: s = v^2 / 2a
So, to adapt voretaq7's example, if your approach air speed is 45 knots, with a 15 knots headwind you land with 30 knots, while with a tailwind you land with 60 knots - now you touch down with four times the energy you need to dissipate, and need four times as much runway to stop (which, happily, lines up nicely with his POH numbers).
Now, finally, one more example:
Suppose the runway is such that with no wind, you can land with approach speed v and just stop prior to the end.
With a (mild) headwind of 10% of your airspeed, you touch down with 0.9v, thus you now use only 81% of the available runway, and have gained quite a buffer.
Whereas, if you have a 10% tailwind, you touch down with 1.1v. Thus, your required stopping distance now is 1.21 times the available runway. When you hit the end now, you'd need 21% of the runway length extra to stop. Now, this gets a bit tricky, but feel free to do the maths, this means that you hit the wall at the end with nearly half of your approach speed, still having about 21% of your (1v) landing energy left to dissipate.
So - what would you rather have, a 20% buffer of runway remaining (with head wind), or hitting the end of the runway with over 40% of your landing speed (with tail wind)? :-)
To answer in part the question of how tailwinds are sometimes mitigated, an air carrier's op specs will typically specify how much of a tailwind is allowed for their operations. The two 747 carriers I flew for allowed a max tailwind of 10 knots.
Whether a captain should choose to land given the max tailwind can be a complicated call. For example, runway 02 at Nadi, Fiji is about 9,000 feet, which makes it a bit of a short field operation for a 747 landing at or near max landing weight, a common occurrence with freighters. In the instance I'm thinking of, we were well inside the outer marker when the tower told us the wind had switched and that there was now a 10 knot tailwind.
I chose to land and here's why:
  • To have gone around would have meant involving ourselves further with the thunderstorms around the field.
  • There was no guarantee that when we approached from the opposite end the wind would not have switched again and we would again be landing with a tailwind.
  • Having landed there many times, I knew our spot on the ramp was very close to the end of the runway, there would be less than a minute of taxi time.
  • I knew the Nadi ground service people were used to using a huffer on hot freighter brakes.
  • I told the flight engineer to call the ground service people and tell them that we would have very hot brakes.
747 tires have 225 psi tires filled with nitrogen, and each tire has a thermal plug that will blow before a tire does. The QRH for handling hot brakes included instructions to warn the ground crew not to stand to the side of the tires, but the Nadi people were well aware of that.
All brake temperature gauges went into the red. I got out of the airplane as quickly as possible to take a look. They already had a huffer on each side of the airplane blowing on the brakes.
  1. because the ground speed would be greater than your airspeed, something you do not want during landing (or take-off): you need at least a certain airspeed to have enough lift, and tailwind would make you too fast w.r.t. ground, making your landing distance much bigger than actually needed
  2. it depends on how much "extra long" and how much "higher ground speed", the aircraft manufacturer will have included tables in the Pilot Operational Handbook, you will have to consult them to verify if it safe or not.
  3. yes, it is indeed switched.
Just an additional human factors flavored aspect:
Your speed relative to the runway is greater than usual. If you start adjusting your relative speed by your usual (headwind) visual reference, this might well lead to a stall situation - never a good thing close to the ground.
With a really good headwind and a little bitty plane (Cessna 150) you can get your groundspeed down to a trot and and just set it on the ground. Have done it at PDK in Atlanta, in March.
Do not do this with passengers. Safety is one reason. Not terrifying them is another.
    $\begingroup$ I've heard numerous anecdotes of C150s landing across the runway when the crosswind component was too high to land conventionally. $\endgroup$ – StephenS Nov 13 '18 at 16:00
An additional issue is that as you descend through the wind gradient-- into the slower-moving air near the ground-- with a tailwind, the aircraft will react just as if it is experiencing an increasing headwind-- it will really want to float. The sink rate will be decreased.
Then when the pilot recognizes his mistake and adds power to go around, the aircraft has to climb up through the wind gradient again. Now the effect is the same as a decreasing headwind-- the climb rate is lousy.
Harnessing these sorts of effects is what "dynamic soaring" is all about-- as practiced chiefly by albatrosses (the birds not the WW1 biplanes.)
One side effect of the extra "floatiness" while landing with a tailwind, due to the wind gradient, is that the actual touch-down tends to be really "greased on" even with less-than-perfect technique on the pilot's part. If you don't want to risk life and limb exploring this effect in a full-sized airplane, you can do it with a radio-controlled model-- make an abbreviated landing pattern with a "hairpin" turn back to the runway after each takeoff, so you can alternate between upwind and downwind landings. You may be surprised at how the downwind landings tend to be consistently smoother than the upwind ones.
One bad scenario is if you are taking off (perhaps after a "touch-and-go" landing) with a nearly direct crosswind, and you accidentally let your heading turn to point toward the downwind edge of the runway. Now your groundspeed is higher than normal, AND the wind gradient is working against you as you try to climb out. The odds of hitting something are much, much higher than if your had veered in the opposite direction, into the wind. And if you DO hit something, you'll hit it with a lot more kinetic energy than if you had veered in the upwind direction.
Pilots of lightweight, slow-flying aircraft need to allow plenty of extra airspeed for the round-out and flare, when landing into the wind in the presence of a strong wind gradient. During the last ten feet or so of descent, the airspeed has a tendency to vanish-- not a good thing if the flight path is still aimed steeply downward.
    $\begingroup$ " During the last ten feet or so of descent, the airspeed has a tendency to vanish--..."-- this of course is the opposite of the "floatiness" experienced when landing downwind $\endgroup$ – quiet flyer Nov 13 '18 at 16:10
