Does existing Avionics / Control Systems on large Commercial Jets make use of differential thrust of engines much?
e.g. I was contemplating applications of this sort: Normally the thrust provided by each of multiple jet engines will be different due to difference in age, wear, build etc. and this is usually compensated by rudder trim.
But instead, would it be feasible for a controller to detect the slight yaw moment and modulate the throttle setting to compensate thereby negating the use of rudder trim?
What about a more general strategy in which the use of rudder trim, or more extremely rudder itself is reduced via automated differential thrust modulation of jet engines? i.e. Using differential thrust not just yaw compensation but yaw creation as well?
Do such systems already exist? Or is there a fundamental flaw in my reasoning that make these ideas not viable?
