A headwind of 20 knots and a true airspeed for the take-off safety speed being 120 knots, the ground speed is only 100 knots. Getting to a true ground speed of only 100 knots will require less distance.
Anyone can explain to me is that mean that the distance for take off will be less and also the take off speed will be less? �
You're correct that a headwind will reduce the takeoff roll (takeoff distance). As far as takeoff speed, the airspeed will remain same, but the ground speed will be reduced.
In the simplest sense, an aircraft rotates for takeoff when it generates enough lift (leaving aside other considerations). This is dependent on the airspeed as the lift generated is propotional to the square of airspeed (provided the other factors like wing area and lift coeffecient are kept constant) at a density altitude. As a result, it is the airspeed, not the groundspeed that matters.
If you have some headwind, the effective groundspeed is reduced by the same amount- resulting in reduced takeoff distance. The effect of the wind on landing distance is similar to the takeoff distance. You can see this in the following figure.
Wind effect
Image from avstop.com
As it can be seen, the presence of winds can have a significant effect on the takeoff disantances required (note that the airspeed remains the same in all cases). Due to this, the direction of prevailing winds can have a significant effect on determining the runway headings. From Influences on Airport Layout:
The weather patterns of an area, especially the prevailing winds, are a major factor in determining runway headings. Prevailing winds are defined as the direction from which the winds blow most frequently. Remember that airplanes take off and land into the wind. Let's say that at a given airport the prevailing winds blow in from the west 65% of the year, while 30% of the year the wind blows in from the east, and the remaining 5% coming from the northwest. It would be best then to orient the runway W (27) and E (9). That would mean that approximately 95% of the year airplanes would be landing and taking off into the wind.
  • $\begingroup$ Technically, in a case where the windspeed would be 120 knots, that plane would be able to hover into wind with a ground speed of zero, but an air speed of 120 knots $\endgroup$
    – Chris V
    Commented Jan 25, 2016 at 23:34
The takeoff indicated airspeed - shown on the ASI in the cockpit - will remain the same regardless of the wind. The groundspeed required to takeoff however, is greatly affected by the wind and ambient conditions.
At a very simplistic level, it helps to think of indicated airspeed as the speed of the air over the wings. Therefore, if an aircraft is sitting still facing a 20kt wind, the speed of air over the wings - the indicated airspeed - is 20kt, yet the groundspeed (speed across the ground) is 0.
So if the aircraft needs to rotate at 120kt indicated airspeed, with a 20kt headwind the aircraft only needs to accelerate to 100kt of groundspeed, and thus requiring less takeoff distance. But the ASI will still show 120kt at rotation speed.
Yes, the distance will be less in both cases because the amount of time needed to reach the take-off speed is reduced because the necessary groundspeed is reduced (minus the time needed for 20 more knots in your case). The landing is also reduced for the same reason - less time is needed to come to a complete stop because the groundspeed is lower than the airspeed (also minus the time needed to shave off those 20 knots). This is the main reason why runways are built in the prevailing wind directions and aircraft carriers steam into the wind when conducting flight operations.
    $\begingroup$ @walidnaceri Take-off speed relative to the ground or the air? Aircraft get their lift from the air moving across the wings; the speed the plane is moving relative to some lump of concrete isn't an issue. $\endgroup$ Commented Jan 24, 2016 at 18:21
    $\begingroup$ Note, however, that it will take longer to reach 100kts with a 20kts headwind than it would take to reach 100kts without that headwind. Also, I'm not sure that reduced take-off/landing distances are the main readon runways are built according to prevailing winds -- avoiding crosswinds is a significant concern. $\endgroup$ Commented Jan 24, 2016 at 18:24
    $\begingroup$ @DavidRicherby can you explain why a headwind will make it take longer to reach 100kts?Seems like it would give you a head start. $\endgroup$
    – TomMcW
    Commented Jan 24, 2016 at 19:05
    $\begingroup$ perhaps include the word "groundspeed" or "airspeed" after all speed references to reduce confusion? $\endgroup$
    – DJohnM
    Commented Jan 24, 2016 at 19:29
    $\begingroup$ @TomMcW If you have a headwind, there's more air resistance so the thrust of your engines gives you less acceleration. (Although I didn't explicitly say groundspeed, I thought it was clear from context.) $\endgroup$ Commented Jan 24, 2016 at 19:39
