I was reading about a C-124 that was carrying three nuclear weapons over the Atlantic, and developed engine trouble. The article said that two of the weapons were jettisoned into the ocean for safety reasons. I was wondering how you can drop something from a C-124 in flight? Unless they were small enough to push out the back side doors. This happened on July 28, 1957.
    $\begingroup$ C-124 cargo doors are in the nose of the aircraft. There's a large cargo elevator at the rear of the plane, but I don't know if it can be lowered in flight. It's suspended by cables. $\endgroup$ Jan 20, 2016 at 4:33
5 Answers 5
11
The C-124 had a opening in the rear, through which cargo (or paratroopers) could be dropped. From globalsecurity.org:
The C-124 was also used for airdrops. ... In the back of the plane, the underneath of the airplane had elevator doors that opened up and the crew could drop cargo out, or paratroopers could jump out.
Here is an image of the elevator doors in open position
C-124
The rear elevator opening of the Douglas C-124 Globemaster II where an elevator platform could be lowered or raised for bulk cargo operations (often the platform was removed so an interior hoist could directly move cargo) — photo by Joseph May; image from travelforaircraft.wordpress.com
Here is a C-124 using that door for an airdrop, presumably in Antarctica (I've put the image as I came across; I'm pretty sure that it's rotated)
C-124 airdrop
Image from antarctica.recollect.co.nz
The crew must've used the rear door rather than the front one for jettisoning the nuclear weapon. The text of the official report reads:
The C-124 aircraft was en route from Dover AFB, Delaware, when a loss of power from the number one and number two engines was experienced. Maximum power was applied to the remaining engines, but level flight could not be maintained. At this point, the decision was made to jettison cargo in the interest of safety of the crew and aircraft. Three weapons and one nuclear capsule were aboard the aircraft, and nuclear components had not been installed in the weapons. The first weapon was jettisoned at 4,500 feet altitude. The second weapon was jettisoned at approximately 2,500 feet altitude.
With the difficulties the crew was experiencing in keeping the aircraft level, it would only be logical that the rear doors were used, not the front.
  • $\begingroup$ I didn't know that the cargo elevator could be removed. Given that nukes of the era were pretty heavy, it makes sense that they might configure the C-124s to fly without the elevator both to save weight and to use a winch to load/unload the bombs. My dad was a paratrooper, and I know he jumped from C-124s but I always assumed he went out the side door. $\endgroup$ Jan 20, 2016 at 16:00
  • $\begingroup$ Looking more closely at the picture, I realized that the chutes are cargo drops. You've pretty much answered my question. The only detail I'd like to clear up is whether the cargo elevator can be jettisoned in flight. You'd think that if you're trying to lighten the plane, that elevator would be a good thing to drop. $\endgroup$ Jan 20, 2016 at 22:39
As a loadmaster on c124s in the 50s the the cargo elevator platform can be jettisoned and cargo can be jettisoned out the opening. The flight manual tells you the clamshell front loading door will never be operated in flight. It has 4 safety large pins installed all the time unless it is in use to load or offload on the ground. I know as I have over 5000 flight hours as a loadmaster on c124s.
If you have oversized items, they go down with you and the aircraft. We did carry parachutes if we needed them.
The flight Manuel tells you the clamshell door will never be operated inflight it has 4 safety large pins installed all the time unless it is in use to load or offload on the ground. I know as I have over 5000 flight hours as a LOADMASTER on c124s.
  • $\begingroup$ I kind of think this is the answer. No way they were going to use the C-124 as a bomber. They'd never be able to get away from the blast radius of a nuke in time. $\endgroup$ Apr 16, 2018 at 21:05
The front doors on the C-124 could NEVER be opened in flight. Doing so would cause catastrophic failure. The door hinges could not take the wind and would certainly take out the two inboard props, and probably the aircraft vertical and/or horizontal stabilizers. If some miracle occurred and the doors flew off without hitting anything else, the drag of that huge open maw would be so great that the only way to fly would be at maximum power, and in a very steep dive. In addition, the skin of this airplane is riveted for outside pressure, not inside pressure. The wind pressure of that 200+ mph wind inside the aircraft would blow out the skin, leaving, at best, an aircraft skeleton. And since the aircraft was semi-monocoque construction, relying on the aircraft skin for a significant part of the integrity of the fuselage, the loss of the skin would certainly cause the fuselage to break in two.
Paratroops exited via two troop doors on the side of the aircraft toward the rear. There were also two troop doors above these, for troop drops using the upper troop floor platforms. However, I have never dropped airborne from the second level, and don't think that it was ever done except, perhaps, in tests or shows. I was with the last Troop Carrier Squadron in MATS/MAC, the 63rd Troop Carrier Wing, which folded Hunter AFB, Savannah, GA, and its use of the C-124, in 1967.
The elevator platform is approximately 8x12' (olllllld memory). The elevator platform was part of and level with the cargo compartment floor, and is held in place by large locking bolts/pistons. The platform is moved up-down, for-aft with two electric winches, which can move the platform down to the ground, and once inside the cargo compartment, to the front and rear of that compartment. The elevator could not be used when the upper troop deck floors were in place.
We carried the upper deck floors on most missions except when the mission order called for their removal. However, when Viet Nam got hot and heavy, I seem to remember not carrying them any more from about 1966 until I left the 61s ATW when they folded their C-124 mission in late 1969. Not carrying the decks yielded a couple of thousand pounds more useful load, and a little bit more room for cargo.
We jettisoned the cargo elevator (with pallets) in flight over the North Atlantic. On another flight while coming in to Sondestrom AFB in Greenland, the upper hinge on the right front clamshell door (viewed from inside while airborne) sheared in flight. We already had 1 engine shut down due to malfunction. I remember loosing altitude at a controlled rate wondering if we would make the coast, and if so, would the door completely fail on impact of landing and foul the main landing gear. We made it to Sondestrom and landed without further incident, but I also remember the pilot stopping on the runway short of smoking the tires as the fire-equipment raced up and surrounded us. We deplaned on the runway.
    $\begingroup$ You might want to post this anecdote on PPRuNE, or another pilot's forum. (That's a heck of a thing you went through). Your first sentence seems to indicate that you were on that flight in 1957. Is this true? If so, a bit more detail might be helpful. $\endgroup$ Feb 24, 2019 at 0:42
If you are desperate enough, even front cargo doors can be opened in flight.
C-124 Globemaster II being unloaded
C-124 Globemaster II being unloaded (picture source)
Note that the hinge line is almost in flight direction. When flying slowly, the aerodynamic loads are small enough to crack the doors open. Actually, their shape will result in a suction force over most of their length, so the hard part is closing them again.
Once the doors are slightly open, the load can be pushed out without much change in the center of gravity since the forward edge of the cargo floor is only slightly forward of the wing's leading edge.
  • $\begingroup$ Thanks for your answer. I'd like to know definitively if this has ever been done. I'm interested in finding if there is a procedure jettisoning any kind of large cargo on a C-124 in flight. $\endgroup$ Jan 20, 2016 at 7:33
  • $\begingroup$ @HowardMiller: I am just speculating and have no information on that particular case. $\endgroup$ Jan 20, 2016 at 7:35
  • $\begingroup$ If you've lost power on two engines on one side of the plane, I doubt you would open the front doors. Too much danger of damaging the good engines. I think @aeroalias is on the right track. $\endgroup$ Jan 20, 2016 at 22:42
  • $\begingroup$ I would hate to think of the kind of drag that would be created by opening those front doors in flight. Especially bad in a plane that has already suffered engine failure and is rapidly loosing altitude. While it might be physically possible to open them in the most desperate situation, are they actually designed to be opened in flight? $\endgroup$
    – FreeMan
    Jun 24, 2016 at 14:23
  • $\begingroup$ @FreeMan: Yes, drag would be terrible if the doors are opened fully. The hinges on the photo also don't look like they have been designed for flight loads. But if you only open them a bit in low-speed flight (when most of the drag is induced, not friction drag), that should be entirely possible. $\endgroup$ Jun 25, 2016 at 6:40
