10
One of the errors for a pitot tube is 'compressibility.' However, I don't understand this in detail. I get that the ASI will read slower because the ram air is compressing against the air already in the pitot tube. My question is when does this happen? What would cause this?
  • $\begingroup$ I am certainly no expert, and I look forward to learning more by reading the answers, but isn't the ram air compressing against the air already in the pitot tube exactly how it measures air speed in the first place? $\endgroup$
    – FreeMan
    Commented Jan 13, 2016 at 17:13
  • $\begingroup$ @FreeMan No. It measures the lower dynamic pressure due to the velocity of the fluid in the tube (Bernoulli's principle). They work just as well (or, given the premise of this question, better) in water, which is incompressible. $\endgroup$
    – Sanchises
    Commented Jan 13, 2016 at 18:21
In subsonic flow, a pitot tube measures the total pressure $P_{0}$, while a static port measures the static pressure $P$. For very small Mach numbers, we can use the incompressible form of Bernoulli's Equation for determining the speed.
As there is no energy due to compressibility, the density $\rho$ is constant. This means that along a streamline,
$\frac{P}{\rho} + \frac{1}{2} v^{2} + gh = constant$
Neglecting gravity, we have,
$\frac{P}{\rho} + \frac{1}{2} v^{2} = constant$
Using this, we can determine the velocity as
$v = \sqrt{2\frac{P_{0}-P}{\rho}}$
This equation, however does not take the effect of comprehensibility into account. While at low speeds this is not a problem, this causes an error as the Mach number increases above ~0.3. As the speed increases above this value, the term $\frac{1}{2}\rho v^{2}$ no longer gives the difference between the Total and static pressure.
In case of compressible flow, neglecting gravity we have,
$\int_{P_{0}}^{P}\frac{dP}{\rho} + \frac{1}{2} v^{2} = constant$
along the streamline as $\rho$ is no longer constant.
For adiabatically expanding gas, we have,
$\frac{P_{0}}{P} = (1 + \frac{\gamma-1}{2} M^{2})^{\frac{\gamma}{\gamma - 1}}$
where $\gamma$ is the specific heat constant and $M$ is the mach number. In this case, the velocity can be calculated as,
$v = \sqrt{\frac{2 \gamma}{\gamma - 1} \frac{P}{\rho} [\frac{P_{0}}{P}^{\frac{\gamma - 1}{\gamma}}-1]}$
This difference gives rise to the error, which is positive i.e. compressibility error produces ASI readings that are too high. In terms of the pressure ratio, the error is more than 8% as the aircraft approaches transonic speeds. The following image shows the difference in pressure ratio between readings using assumptions of incompressible and compressible flow.
Compressibility
Image from Mechanical Measurements and Metrology - Measurement of Fluid Velocity by S. P. Venkateshan
Basically, the issue is with the assumptions in the method use to calculate the velocity- for low speeds, we assume that the density is constant, which is clearly not the case as the speed increases. Usually, M = 0.3 is taken as the cutoff point.
    $\begingroup$ "does not take the effect of comprehensibility into account" - are you talking about your answer in general, or the equation? $\endgroup$ Commented Jan 13, 2016 at 22:38
