Aerion together with Lockheed Martin is building the AS2 supersonic jet. This is the most realistic SS business jet project of all time. But what do they mean by SNLF technology which claims to reduce drag? And how is it better than the delta wing which they claim is inferior.
  • $\begingroup$ It does not say what it is. It's just a 2 page press release :/ $\endgroup$ – user12782 Jan 11 '16 at 10:48
  • $\begingroup$ "This is the most realistic SS biz jet project of all Time". What is SS? Supersonic? $\endgroup$ – mins Dec 21 '17 at 21:21
SNLF stands for Supersonic Natural Laminar Flow.
Laminar flow over the wing reduces the friction drag. Achieving this has been the aim of a number of designs, from the laminar flow airfoils of the past to the latest 737 MAX winglet. While it is difficult enough to achieve in subsonic flight, the high wing sweep and Reynolds number in supersonic aircraft make it much more difficult to achieve.
One method of achieving this is to use wings with low sweep (unlike delta wings) and sharp (supersonic leading edges) at the expense of other forms of drag.
SNLF
Dark colors show the expected laminar flow regions, while the graph shows the pressure gradients. Image from Unconventional Configurations for Effecient Supersonic Flight by I. Kroo
A number of designs have been proposed to this end from reverse delta to the Aerion's design, which looks strikingly similar to F-104 starfighter.
One method of achieving the laminar flow (i.e. extending it chordwise) in supersonic flight is by using laminar flow control (LFC) methods like suction etc. A good example is the use of suction in a F16XL test aircraft by NASA, which produced laminar flow over nearly half of the wing (less than the design value though).
F16 XL
F16XL with porous titanium LFC glove on the left wing, image from NASA report TF-2004-12 DFRC, F-16XL Supersonic Laminar Flow
The problem with LFC is that it increases weight and takes up space in the wing, hardly an advantage in a supersonic aircraft. So, the next thing to do is increase the laminar flow distribution without using any mechanical (or other) aids.
Natural laminar flow means the presence of laminar flow even in the absence of any LFC measures. From NASA F-16XL Supersonic Laminar Flow document:
Passive laminar flow can be achieved in the wing design process, .... Passive laminar flow can also be created on an existing wing by altering the cross-sectional contour of the lifting surface to change the pressure gradient. Both of these laminar conditions are called natural laminar flow.
SNLF then, is basically laminar flow in supersonic flight without the aid of active boundary layer control methods.
SNLF has been demonstrated in the past (unsurprisingly in F-104), but the tools to analyze it and replicate it in other aircraft were lacking. This seems to the main thrust of the Aerion.
The AS2's wing design has been tested by NASA in a F-15 and the results seem to be encouraging.
SLF
SLF flight test on F-15 with NASA Dryden (top). Predicted transition (left) and infrared image (right) showing extensive natural laminar flow. Mach 1.8, 40,000 ft., Reynolds Number about 10 million. Image from Unconventional Configurations for Effecient Supersonic Flight by I. Kroo
Aerion doesn't say that delta wing is inferior, but it is a simple fact that you can't use a delta wing for supersonic laminar flow. Aerion claims that its design will have 20% less drag than delta wing, but till the aircraft actually flies, we should take its announcements with a large dose of salt.
There are other problems the company has to overcome if the product is to be successful- if the wing is thin (as I expect it to be) and quite small, the aircraft's range appears wildly optimistic. For example, the F-104 had thin wings, but had the fuselage to put the fuel in; something that is very difficult in AS2 unless the passengers agree to carry some. Also, the small wing size may lead to quite high landing speeds.
AS2 F104
Planform comparison of AS2 (top) and F-104. Not to scale. AS2 from company website; F-104 from Wikipedia- attributed to Kaboldy.
  • $\begingroup$ Maybe it can carry fuel in the fuselaege. Passenger cabin doesn't take half the length from what I see in the pictures. It's 52m in length while the concorde was 62m and could carrry 100 passengers. $\endgroup$ – user12782 Jan 11 '16 at 14:46
  • $\begingroup$ It's not just small wing, but also the profile. The leading edge has low sweep, so it must be sharp for supersonic flight, but sharp leading edge means low stall angle of attack, which further increases the landing speed. For a fighter (F-104) they could have said if slats fail, the pilot will eject. But a passenger plane must be able to land with flap+slat failure… $\endgroup$ – Jan Hudec Jan 12 '16 at 14:05
