Maximum theoretical lift of a plane as a function of engine power and surface of the wings?
I know that the maximum static thrust of a propeller turned by an engine of power $P$ can not be greater than: $$Thrust_{max}=\sqrt[3]{2\pi(\frac{D}{2})^2 \rho P^2}$$ where $\rho$ is the density of the air and $D$ the diameter of the propeller.
I am looking for a formula that gives the maximum theoretical lift of a plane which flies horizontally. After half a page of demonstrations I have found a relation:
$$Lift_{max}=\sqrt[3]{2S \rho P^2}$$ but I am not sure if it is correct ($S$ is the total surface of the wings).
Update 1
Two examples that show the formula for max lift gives lifts smaller than the loaded weight of the plane. I do not know why.
1) Cessna 172: Gross weight - $1,111kg$, Powerplant - $160 hp$, Wing area - $16.2 m^2$
$Lift_{max}=(2 * 16.2 m^2 * 1.2 kg/m^3 * (160 hp)^2)^{1/3}=837 kgf<1,111kgf$
2) de Havilland DHC-6 100 Twin Otter: Gross weight - $5,246kg$, Powerplant - $2*579 eshp$, Wing area - $39 m^2$
$Lift_{max}=(2 * 39 m^2 * 1.2 kg/m^3 * (2 * 579 hp)^2)^{1/3} = 4,198 kgf<5,246kgf$
Update 2
I have tried a different demonstration that stars from the known relations: $$Lift={0.5 \rho S C_L V^2}$$ $$Drag={0.5 \rho S C_D V^2}$$ $$Power=Drag * V$$ By eliminating the speed of the plane, $V$, the lift result as being: $$Lift = \sqrt[3]{2S \rho P^2 \frac{C_L^3}{4 C_D^2}}$$ It appears that this new lift can be greater than $\sqrt[3]{2S \rho P^2}$ as long as $\frac{C_L^3}{4 C_D^2}$ does not seem to be restricted to always remain less than 1.
Update 3
Using the formulas for $C_D$ an $L_{max}$, suggested to me by Peter Kampf and mnunos, I have made some evaluations.
$$C_D = C_{D0} + \frac{C_L^2}{\pi\cdot AR\cdot\epsilon}$$
$$L_{max}=\frac{1}{2}\cdot \sqrt{3\pi AR\epsilon}\cdot \sqrt[3]{\frac{P^2\eta^2\rho S}{4 \sqrt{C_{D0}}}}$$
For the assumed values: $\eta=0.7$, $\epsilon=0.8$, $C_{D0}=0.03$, $\rho=1.2\: kg/m^3$ and the data taken from the Cessna 172 general characteristics: $P = 160\:hp$, $S=16.2\:m^2$ and $AR=7.32$, I get: $$L_{max,\:\eta=0.7}=2199\:kgf$$ However, only $57.451\:hp$ are necessary for lifting $1111\:kg$ (horizontal flight), the rest up to $160\:hp$ can be used for climbing.
From the relation:
$$m_{plane}gV_{climb} = \eta(160\:hp - 57.451\:hp)$$
I get $V_{climb}= 4.913\:m/s$ which is significantly greater than the rate of climb 3.66 m/s the Cessna 172 has.
It seems that working with $C_{D0}$ and $\epsilon$ gives only a quite rough estimate of the max lift. Without knowing the actual $C_L=C_L(C_D)$ little can be said about the real maximum possible lift of a certain plane.
Update 4
The maximum theoretical thrust of an ideal helicopter propeller having the diameter identical to the wingspan, $11\:m$, of a Cessna 172:
$$T_{max,Diameter\:prop=11\:m}=(2 * pi * (11 m / 2)^2 * 1.2 kg/m^3 * (160 hp)^2)^{1/3} = 1 509.95\:kgf$$
is considerably smaller than the max lift of the plane, $L_{max,\:\eta=0.7}=2199\:kgf$, I calculated in Update 3. Is such a result logical? Does it have an explanation?
