For flight operations conducted under 14 CFR part 91(other than subpart F) in VMC, what conditions constitute "known icing conditions"? Under what circumstances (e.g., altitude difference or no visible moisture), if any, could a VFR flight operation (other than in an aircraft certified for flight into known icing) be legally conducted despite an Area Forecast, AIRMET Zulu, Pirep or other possible indicator of known icing conditions?
$\begingroup$ I was always told that airframe icing will only occur when flying into visible moisture. Maybe my flight instructor was wrong, but he seemed to be pretty smart... $\endgroup$– Ron BeyerJan 4, 2016 at 16:41
$\begingroup$ @Ron, I think that's true, but VMC can include flight through varying degrees of visible moisture. $\endgroup$– J WJan 4, 2016 at 16:49
$\begingroup$ Visible moisture in the air is a cloud, rain, or snow, on the ground its fog. VMC you need to remain free of clouds in all VFR conditions, the only questionable one I think is ground fog where visibility is still VFR. $\endgroup$– Ron BeyerJan 4, 2016 at 16:52
2$\begingroup$ @Ron, visible moisture can also include precipitation, which can cause airframe icing. $\endgroup$– J WJan 4, 2016 at 16:54
$\begingroup$ Right, I edited my comment probably before you saw it, my point is to dispute this in your post: "Under what circumstances (e.g., altitude difference or no visible moisture)", I'm pretty sure you can't have airframe icing without visible moisture. $\endgroup$– Ron BeyerJan 4, 2016 at 16:56
The short answer is that it's up to you as PIC to make that determination; the FAA has no clear definition apart from what a "reasonable and prudent" pilot would do.
The FAA issued a legal interpretation on exactly this question in 2009, here's the closest thing to a definition that they give (my emphasis throughout):
"Known icing conditions" involve instead circumstances where a reasonable pilot would expect a substantial likelihood of ice formation on the aircraft based upon all information available to that pilot. While "known icing conditions" are not defined by regulation, the term has been used in legal proceedings involving violations of FAA safety regulations that relate to in- flight icing. The National Transportation Safety Board (NTSB) has held on a number of occasions that known icing conditions exist when a pilot knows or reasonably should know about weather reports in which icing conditions are reported or forecast
They go on to say that the PIC is responsible for determining the likelihood of icing conditions:
Any assessment of known icing conditions is necessarily fact-specific. Permutations on the type, combination, and strength of meteorological elements that signify or negate the presence of known icing conditions are too numerous to describe exhaustively in this letter. Whether a pilot has operated into known icing conditions contrary to any limitation will depend upon the total information available to the pilot, and his or her proper analysis of that information in evaluating the risk of encountering known icing conditions during a particular operation. The pilot should consider factors such as the route of flight, flight altitude, and time of flight when making such an evaluation
Note that even visible moisture and freezing temps aren't automatically considered to be known icing conditions:
The FAA does not necessarily consider the mere presence of clouds (which may only contain ice crystals) or other forms of visible moisture at temperatures at or below freezing to be conducive to the formation of known ice or to constitute known icing conditions.
The specific regulations mentioned in the interpretation are 14 CFR 91.9 (compliance with the operating manual), 91.13 (no careless or reckless operation) and 91.103 (become familiar with all information relevant to the flight). Those regulations would be the basis for any hypothetical enforcement action:
If the composite information indicates to a reasonable and prudent pilot that he or she will be operating the aircraft under conditions that will cause ice to adhere to the aircraft along the proposed route and altitude of flight, then known icing conditions likely exist. If the pilot operates the aircraft in known icing conditions contrary to the requirements of § 91.9(a), the FAA may take enforcement action.
So the bottom line is: you're PIC and it's your decision whether it's safe to fly or not because there are far too many variables for anyone else to decide. But personally I think it would be difficult for any pilot to say that it was "reasonable and prudent" to fly a non-FIKI aircraft in an area where forecasts, AIRMETs or PIREPS indicated icing.
$\begingroup$ The last sentence of your question captures the sentiment that led me to ask the question in the first place. Would you consider that it was "reasonable and prudent" to fly a non-FIKI aircraft in an area where forecasts, AIRMETs or PIREPS indicated icing, if you maintained VMC and avoided areas of precipitation that caused ice accretion? $\endgroup$– J WJan 4, 2016 at 17:42
1$\begingroup$ What is reasonable depends entirely on what the pilot observes. All the legal interpretations, forecasts, and even pireps count for nothing if your observation of the actual weather conditions at the exact time and altitude you penetrate an area of forecast icing indicate to you that it's safe. This FAA interpretation only simplifies enforcement action after a plane turns into an ice block. As far as I can tell, it has no practical value other than helping the FAA build a case for a violation. $\endgroup$– acpilotJan 4, 2016 at 18:59
2$\begingroup$ @JonathanWalters Maybe, but it all comes down to the details. How high are the ceilings? Where's the freezing level? Are there any fronts moving around? Do I know the route and aircraft well? Etc. At one extreme I'd certainly do pattern work, but at the other I wouldn't set off on a 250nm night XC. In the end this is all about risk, experience and judgement: I might refuse to fly in conditions that an Alaskan pilot wouldn't hesitate to fly in. And we might both be 'correct' about our decision. $\endgroup$– PondlifeJan 4, 2016 at 19:00
1$\begingroup$ Re "The link to the legal interpretation is dead" -- it works now, and any answer containing a link to an actual interpretation of this nature automatically gets an upvote from me-- thanks for fixing J Walters-- $\endgroup$ Jan 12, 2022 at 2:45
I applaud the FAA for attempting to add clarity to a difficult subject. One of the points in the FAA’s legal interpretation I took, was the importance of the pilot determining an “Exit Strategy” in their flight planning: what to do should the pilot encounter airframe icing in-flight. This approach is similar to the way we are all taught to look for a field for an emergency landing in case of a loss of an engine (i.e., SEL Airplanes).
The “reasonable and prudent” is the part that concerns me. What is “reasonable and prudent” to a pilot with years of experience may not be to a pilot with just a few years of experience. Perhaps the FAA considers “reasonable and prudent” in the context of other pilots with the same experience level, but that is not how I read the letter. Legal Interpretations can be found below in the event the AOPA website link breaks. https://drs.faa.gov/browse/LEGAL_INTERPRETATIONS/doctypeDetails
$\begingroup$ I'm not seeing that this provides an answer to the stated question. $\endgroup$– Ralph J ♦Oct 27 at 17:27
$\begingroup$ I think you might be interpreting “reasonable and prudent” as if it is a subjective non-entity, i.e. based mostly on opinion which could vary depending on the individual and experience. The concept is actually more one of a fixed reality which requires judgment to ascertain. Pilots are expected to begin developing various types of judgment pretty early in the training process. With experience judgement can improve, but it's an improvement in recognizing the reasonable and prudent decision, it doesn't change what the reasonable and prudent decision is. $\endgroup$ Oct 30 at 11:50
$\begingroup$ The question "Under what circumstances (e.g., altitude difference or no visible moisture), if any, could a VFR flight operation... " The answer "Have an Exit Strategy". $\endgroup$– Greg R.Oct 30 at 13:30
