12
A company called Windspeed Technologies posted the following concept video of a panorama seating option aboard a commercial plane.
From the limited understanding I have of the phenomena called flow separation, such a structure on the fuselage may induce separation.
Separation around a sphere
The sphere example here is just an approximate representation for the semi-ellipsoid.
The reason I am asking this question, is because the ellipsoid is relatively near the tail section of the plane. It does not seem like a good idea to have a turbulence inducing structure that close to the tail.
How will this addition to the plane fuselage effect the air flow ? Worst case, can it cause navigation problems due to turbulence near the tail section ?
13
You're correct that the structure may induce separation under some conditions. However, the effects are unlikely to be significant given the (publicly) available data on the concept. From the available images, the deck is quite small, with a seating capacity of only two.
Skydeck
Image from gizmag.com
Also, it is located at some distance in front of the vertical fin and appears shaped to reduce drag.
Skydeck
Image from technology.org
The company says that it has over come many design hurdles including
... structural modification, structural integrity of the canopy to withstand a bird strike and flight loads, condensation, noise levels, UV protection, aerodynamic drag, potential disruption to the vertical tail's performance, safety, ingress and egress requirements per the FAA requirements.
Though this should be taken with a grain of salt (it from the company after all), there is nothing insurmountable in the engineering sense. For example, the canopies of fighter jets are of similar size in smaller aircraft and they are operated without problems.
AWACS aircraft routinely carry huge antenna on top of their fuselages; they have no problem flying, albeit with reduced performance. For example, the following image shows the E-767, the AWACS version of Boeing 767 operated by the JASDF.
E-767
"E-767 Japan AWACS 112010" by Jerry Gunner - AWACS Boeing E-767 of Hiko Keikai KanseitaUploaded by Altair78. Licensed under CC BY 2.0 via Commons.
However, it is another matter if this is going to enter into service. My take would be that this is not going to happen in current time for a number of reasons including:
  • The cost quoted is pretty high and downtime, too long.
  • cutting up pressurized fuselage is not a good idea.
  • The concept is going to take up seats and increase weight for questionable benefits. What are you going to see up there? the same clouds that you are going to see from normal windows anyway.
So, the "cupola" on top of the airplane is more of a teardrop shape than spheroid or ellipsoid. Many of the control surfaces on aircraft use this shape, so the induced/pressure drag caused by it would not be much and since it is smaller than those surfaces, it would have less of that drag. The addition of that surface adds more surfaces area, which creates more, though somewhat negligent, parasite drag. Overall, the airworthiness of the airplane would not be affected much, although a Supplemental Type Certificate (STC) would be needed to add the structure on.
  • $\begingroup$ Which control surface is shaped that way? $\endgroup$
    – JustSid
    Jan 1, 2016 at 12:24
  • $\begingroup$ @JustSid Wings, horizontal and vertical stabilizers, canards, &c The copula just has a different size ratio than those surfaces. $\endgroup$ Jan 1, 2016 at 13:16
  • $\begingroup$ Is a copula what results from having two cupolas side by side? $\endgroup$
    – user403
    Mar 12, 2019 at 21:16
Any kind of change to the aerodynamic envelope does have an effect on airflow over that section. This would have been analyzed by engineering using competent CFD modelling and wind tunnel testing. The end result here is that the effect is probably minimal for several reasons:
First, competent shaping of the protrusion should result in minimal disturbance to the airflow in that region. Second, the blister shape is mounted on the aft dorsal section of the fuselage, where we would already predict the boundary layer airflow to be turbulent, so flow separation is a minimal issue here. Third, if the shape is sufficiently placed upstream of the control surfaces and the cross sectional area of the affected surface is limited (say, 5-10% of the total surface), the impact on flight control should be minimal and more than acceptable.
