What are the FAA regulations on grass airstrips like grass height, lighting, necessary aircraft equipment, and the like?
$\begingroup$ If you're asking where to find these regs, I think this question is entirely on topic. If you're asking for them all to be listed here, I think the question is too broad. $\endgroup$ – Steve V. Dec 11 '15 at 3:32
I went poking around the FAA Regulatory and Guidance Library until I found FAR 139.307, which states:
Sec. 139.307
Unpaved areas.
(a) In a manner authorized by the Administrator, each certificate holder [must] maintain and promptly repair the surface of each gravel, turf, or other unpaved runway, taxiway, or loading ramp and parking area on the airport that is available for air carrier use as follows:
(b) FAA Advisory Circulars contain methods and procedures for the maintenance and configuration of unpaved areas that are acceptable to the Administrator.
So I went looking for those advisory circulars. There are probably more that I haven't found, but AC 150/5300-13A - Airport Design beginning at page 82 seems to have the sort of thing you're looking for.
