If an engine's horsepower is increased will max gross weight be increased?
For example what is the effect on max gross weight of changing the engine on a small GA airplane from 65hp to 100hp.
Sign up to join this communityIf an engine's horsepower is increased will max gross weight be increased?
That is a certification issue. It depends on what limits the particular max gross weight for that aircraft. If the design happens to be limited by the max weight that the landing gear can handle, then hanging a heavier engine with a high HP, would not change the max gross, but would decrease the max payload.
First, you ask one thing in the title and another in the text of your question. Useful load is the sum of fuel and payload, whereas the gross weight is the force produced by the mass of the whole aircraft in the gravitational field of Earth.
If you change engine power during airplane design, gross weight will go up. At that point, you will have relative parameters like wing loading (kg/m²) and power loading (kW/kg) defined and will size the aircraft accordingly.
If you switch the engine of an existing aircraft to a more powerful one, you will need to modify the airframe and systems if the aircraft had not been designed for the more powerful engine initially. Now your gross weight is already defined and cannot simply be changed. Let's first see what happens if a more powerful and heavier engine is fitted:
For now, let's assume that you stick with the old gross weight and reduce payload accordingly, because you do not want to rivet doublers all over the structure. Fine, but we are not done yet.
You see, you cannot legally escape. Fitting a more powerful engine will require adaptions in the structure, and once you need to reinforce wings, landing gear and fuselage, you can as well choose a higher gross weight. But now you need to re-size the structure and re-certify the modified aircraft.
And we have not even started to look at the systems:
The list goes on, but this shall suffice.
Now to your specific case: If you want to keep the power loading constant (which will give you the same performance as before), the airplane gross mass goes up by 54%, and so does the wing area.
If you want more performance, you will need to reinforce the structure (or start all over with a new design of the same size), and now it is up to you which gross weight to pick. The heavier engine and structure will eat into your payload and fuel, but if you accept that limitation, you can fly with the same gross weight as before.
As you can see from the first part of the answer, useful load is reduced by fitting a heavier and more powerful engine. Only when you re-work the structure to cope with the higher loads can you raise wing loading and regain the loss in useful load. Whether you can increase it by more than what you have lost so far depends on the maximum wing loading.
Let's assume for the rest of the answer that the outside shape (wing area, airfoil etc.) will stay identical to the original aircraft, except for maybe a bigger cowling, propeller and radiator.
The mass increase of the power plant plus its supporting structure is linear to the increase in performance. To beef up the structure, you could use the same percentage rule to stay on the safe side, but the real increase will be smaller. There are books which list parametric formulas for airplane masses, and those will show you the influence of the main parameters. They show that wing mass goes up with the square root of dive speed. Since speed is proportional to the third root of engine power, you will see that 54% more power means 15.5% more speed and 7.5% more structural mass.
Now let's assume that the propulsion system is 15% of the aircraft mass, and structural mass is another 40%. Your empty mass will go up by 8% (engine) and 3% (structure), and if your useful load was 30% of gross weight before, it will now be down to 19% of the same mass. Now we need to bump up the gross mass, and go for half of what you would gain if you keep power loading constant. This means your gross mass is going up to 127% of the original gross mass.
Before you rejoice that now your useful load has gone up to 46%, we need to account for the additional structural reinforcement that this gross mass increase produces. The parametric formulas give a structural mass increase proportional to m$_{gross}^{0.3}$ for the fuselage and m$_{gross}^{0.7}$ for the wing, and a higher wing loading will again result in a dive speed increase, so your total structure will now maybe weigh 15% more than before, for a total of 47% or 48% of the initial gross mass. Yes, your structural mass fraction will go up when you increase wing loading! But still a sizable increase in useful mass should remain - you will now have 39% or 40% of the original gross mass available for fuel and payload, for a relative increase of 30% over the original useful load.
Now I never tried to keep minimum speed constant, but that would had complicated this answer even more. If the original plane had no or very simple flaps, this would be quite feasible, but result in almost a new wing design.
Cessna 140s can be fitted per STC rules with a Lycoming 0290D2 or 0290D or 0235 and do need extra weight in the aft section to get the CG right. Useful load goes down. The gross weight stays the same. Depending on many factors and perhaps operational safety one might get a gross weight increase approval for instance extra fuel if all other factors made it safe and reasonable. Most designs did not factor in larger than the engine used for the design and weight must have a certain "cushion of safety" like 150 percent above normal operating limits designed in. Certified VS Experimental and usage like holding out to the public for instance part 135 or part 121, racing planes etc. also effect allowable limits. Most basic a safety issue and thus a regulation effect concerning safety governs increases in gross weight.
The short answer to your question is yes. However there are often other things involved than just increasing the horsepower (but anecdotally that has worked in the past). For example the Piper Cherokee line which goes from a 140HP all the way up through the Dakota which sports a 235HP engine on effectively the same airframe saw an increase in useful load as the horsepower increased (there were some aerodynamic changes that help over the years as well, like the swept wing that was introduced later).
There is a practical limit to this of course. First off there are engine size vs airframe limitations. For example you most likely can't bolt a Merlin engine to a Piper Cub frame (but I'm sure someone has considered it). There are also CG limits to take into account as your engine grows but airframe might not. CG loading can become an issue with very heavy engines up front.
In some regards wing loading will come into play here. Since a bigger engine will help you overcome drag and fly faster you can generate more lift and thus lift more.
