27
As I have never flown inside a cockpit, but only played with simulators I find that the dashboard takes most of the field of view(or am I wrong?).
So what actually can pilots see given good weather conditions, especially during critical parts of a flight, like take-offs and landings ?
I'm generally interested in big airliners.
P.S. I am not asking if they could takeoff/land without visual contact.
    $\begingroup$ You tagged this visual-flight-rules, are you interested in VFR/General Aviation or actually commercial airliner? $\endgroup$ Nov 24 '15 at 14:44
    $\begingroup$ I added a question with an impression for a general aviation aircraft nevertheless. I am sure others will be able to provide pictures or references for airliner cockpits. @phantomazi $\endgroup$ Nov 24 '15 at 14:52
    $\begingroup$ flight sim displays are not representative generally because the limited screen size and the need to display instruments means little room is leftover for visuals. Some get around that with virtual 3d cockpits (x-plane) or by using many monitors or dedicated devices to simulate the avionics. $\endgroup$
    – casey
    Nov 24 '15 at 15:43
    $\begingroup$ When I played simulators, a BIG difference was when I bought some hardware -- the PC screen could be used almost as a windshield, and the point of view was a bit more realistic. Now I'd like to try a virtual reality helmet... $\endgroup$
    – orique
    Nov 24 '15 at 17:48
    $\begingroup$ Related: How do larger aircraft compensate for reduced visibility from the cockpit? $\endgroup$
    – Farhan
    Nov 24 '15 at 21:25
18
This really depends on the type of aircraft and the seating position of the pilot. In smaller aircraft, you will have a good view of the area around you, depending on the canopy. In larger aircraft, the instrument panel and cockpit design can restrict your outside view a bit more.
Below you will find two pictures taken from the cockpit of a Super Dimona HK36, used for VFR general aviation flights. Both are approximately at eye level.
Dimona Cockpit 1
(Source: Own Work - SentryRaven)
Dimona Cockpit 2 (Source: Own Work - SentryRaven)
In a document A319/A320/A321 Flight Deck and Systems Briefing for Pilots (can be found in many places on the net, e.g. on slideshare as presentation), or page 16 Airbus shows following diagram of visibility from cockpit:
A319/A320/A321 flight deck - pilot's field of view
17 or 20 degrees below horizon is not that bad. It is probably a little less than you see from a typical car, but not by much (of course since the pilots are sitting much higher, the nearest point on pavement is correspondingly further away).
Note, that whether the above is actually true depends on how the pilot adjusts their seat. The recommended height for eyes is marked on the post between the forward windows.
  • $\begingroup$ As a side note, a saw in a video once that the MD-80 actually has a sight on the dashboard that you line up with when adjusting your seat so that you get maximum visibility. Always thought that was interesting $\endgroup$
    – TomMcW
    Nov 24 '15 at 19:09
    $\begingroup$ @TomMcW, it is not on a dashboard, it is on the post in the middle. It is three balls that you need to see at the same level. All or most aircraft have that. $\endgroup$
    Nov 24 '15 at 19:26
    $\begingroup$ Here is a random blog post with images of two different seat position sight gauges. I'm not sure what the correct terminology is to search for other images or description, although the ATR-72 Flight Manual has a low-quality description on page 9 if it's of interest. $\endgroup$
    – MichaelS
    Nov 25 '15 at 0:18
13
In general, the pilots are required to have good visibility to execute any maneuvers during normal operation of the aircraft. According to Federal Aviation Regulations Part 225, Section 773- Pilot Compartment View, during non-precipitation conditions,
Each pilot compartment must be arranged to give the pilots a sufficiently extensive, clear, and undistorted view, to enable them to safely perform any maneuvers within the operating limitations of the airplane, including taxiing takeoff, approach, and landing
The FAA advisory Circular 25.773-1 Pilot Compartment View design considerations gives certain guidelines for ensuring pilot visibility.
Pilot view
Pilot compartment view from FAA AC 25.773-1 Pilot Compartment View design considerations
The figure shows a pilot compartment view for optimum collision avoidance when seated in the left (port) seat. For the starboard side, all left/right dimensions are reversed.
Usually, the aircrafts offer better visibility compared to the guidelines. For example, the A330's visibility (from Flight deck and system's briefing) is given here.
A330 pilot view
Image from A 330 Flight deck and system's briefing
The actual visibility of the pilots will vary according to the seat position For example, the following figure shows the variation in pilot visibility in Boeing 727 when seat position is adjusted.
Boeing 727 Visibility
Image from Airplane Design- Layout Design of Cockpit, Fuselage, Wing and Empennage by Jan Roskam
Of course, the pilots can see things which is normally not visible though the windows through cameras mounted on the outside, like on top of vertical tail in A380.
This might be a stupid answer, but you can see a lot of take-off, landing videos from cockpit in YouTube.
Here's one:
I'll illustrate some aspects which I think even the best flight simulation today cannot compensate:
Peripheral vision
Telling distances and relative positions is much easier. For example, you can tell a certain building is 1000 feet away. When you are landing, you can take a quick glance to either side of the runway and judge whether it is time to flare.
Sitting in the cockpit of a 747 feels rather like standing on top of a 3-story building. The best part is, this building moves! It's truly amazing.
Detailed view
I know this sounds obvious, but I have to put it as number two. Even when you are on final, you can see the little cars with people moving around the ramp and terminal. The cockpit glass is just like the windshield in your car; if you can see something directly, you will see it in the cockpit.
You will also see the small cracks in the windshield, especially when sunlight is directly shinning at it. This is a natural property of the material used.
If you're flying a single-engine propeller plane, your view will be slightly obstructed by the spinning propeller.
Other planes
Spotting other planes in a real cockpit is a bit tricky. If the plane is below you, and you're flying over residential areas with lot of houses, it can be hard to spot.
    $\begingroup$ The difficulty of spotting aircraft is much greater than one would at first imagine, I would absolutely agree. $\endgroup$ Nov 24 '15 at 23:38
As stated in the comments, the view you get in a PC based flight simulator is not representative of the real thing. To get a decent approximation of what you actually see from an airliner cockpit you'd need at least 6 screens in 2 rows of 3 screens each.
This of course requires quite a bit of hardware to accomplish :(
Using the virtual cockpit feature of some flight simulator software, and cranking up your viewpoint a bit from the default settings, you can get a much more authentic experience already but it's still limited by the tiny viewport offered by even a larger widescreen computer monitor (let alone a 17" 4:3 display which is what many of them are programmed for as it's the smallest common denominator).
Of course that virtual cockpit has its own drawbacks in that the instruments are often a bit blurry and buttons and knobs less responsive than in the 2D view (let alone reality).
It's a set of compromises we have to live with as PC flyers, dictated by the limitations of our hardware and budgets.
