I have heard that propellers with more than four blades are not as efficient as 4 or less blades because of lower thrust which may result from interfering prop-streams. But I see the ATR-42/72 and they have 6 blades. What is the reasoning and the advantages to that prop layout?
$\begingroup$ There are many ways to define "efficiency" so please give us clarification if possible. Cost per thrust? Thrust per weight? Even noise per weight? For starters, more blades produce more interference with each other (they pass through each other's wake), and more blades tends to incur more maintenance costs. $\endgroup$– DrZ214Nov 19, 2015 at 5:48
1$\begingroup$ Related: aviation.stackexchange.com/questions/13545/… $\endgroup$– Peter KämpfNov 19, 2015 at 7:47
$\begingroup$ You're partially right. More blades are less efficient. But more blades produce HIGHER thrust, not lower. More blades = more thrust with more drag which reduces fuel efficiency. Less blades = less thrust with less drag increasing fuel efficiency. If at all possible, aircraft designers would prefer to increase thrust by using longer blades. But there are limits to how long you can make landing gears. So if you can't go longer, add more blades. $\endgroup$– slebetmanApr 16, 2016 at 16:55
You are right, more blades are bad for efficiency (follow the link for the definition). Ideally, a propeller should have only one blade. Every additional blade will cause disturbances which interfere with the flow on the other blades.
When engine power increases, the propeller disc area should also grow, but this growth is limited by the resulting speed of the blade tips. Once the flow speed there becomes supersonic, the drag at this section of the blade increases without a corresponding increase in thrust. To avoid that, the next best option is to increase the solidity ratio of the propeller, called also the activity ratio. This is done by either increasing blade chord or the number of blades.
Make no mistake, this is bad for efficiency. But if there is enough power available, adding more blades is the best way to transform that engine power into thrust.
Take the Supermarine Spitfire:
- The prototype, powered by the 1,030 hp Rolls-Royce PV-12, had a two-bladed propeller
- From the Mk II, a three-bladed propeller was fitted to accommodate the increasing power of the RR Merlin (1,470 hp for the Spitfire Mk V).
- With the Mk IX, a four-bladed propeller was needed for the 1,575 hp of the supercharged Merlin 61.
- From the Mk XII, the more powerful Rolls-Royce Griffon made a five-bladed propeller necessary. Engine power was raised from 1,735 hp to 2,300 hp for the last variant, the Mk XXIV.
Rolls-Royce Griffon-powered Supermarine Spitfire (picture source)
A lower prop speed allows to increase its diameter, but while tip speed will drop by less than the reduction in prop speed (after all, flight speed should not change), the available thrust from this propeller will drop by the square of the speed reduction, since thrust is proportional to the dynamic pressure on the blades. And thrust you get only from the circumferential fraction of the local speed at the blade; flight speed does not count here and does not help to mitigate the reduction. Consequence: You cannot make the propeller bigger and spin it more slowly for a given power.
An extreme example for a propeller with a high activity ratio is the Aerosila SV-27 contra-rotating propeller of the D-27 propfan engine powering the Antonov An-70:
SV-27 propellers on the An-70 (picture source). Eight blades in the forward disc and six in the rear, running at only 1200 RPM. In order to reduce Mach effects, all blades have a swept tip and deep chord.
This can only be topped by something like an ungeared turboprop with a ducted propeller. A turbofan, in other words.
$\begingroup$ So then, for a contra rotating propeller, do designers accept a loss of efficiency as a acceptable penalty for the other benefits of such a design? $\endgroup$ Jul 2 at 0:44
1$\begingroup$ @CarloFelicione No, contra-rotatig props have a higher efficiency because they reduce swirl losses (which are higher with higher power loadings). Their disadvantages are higher mass and complexity, of course. $\endgroup$ Jul 2 at 6:00
First, we have to define what is efficiency. In case of propeller, we can define efficiency as the ratio of output power (ability of the propeller to produce a given thrust at a given airspeed) and input power (i.e. the shaft power of the engine).
All else held constant, the efficiency the propeller decreases as the number of blades increase due to aerodynamic reasons (like interference). However, if the engine power is increased, the propeller should be able to 'absorb' that; i.e. transmit engine power to the air flow passing through the propeller disk, adding energy and generating thrust.
If the engine power is increased, there are a number of ways to make the propellers absorb it, each with is own share of issues:
Increase angle of attack i.e. blade pitch- The pitch angle is usually set at a value where the aerodynamic efficiency is optimal. Changing it may make the blade inefficient.
Increase the blade diameter The causes two major problems- Longer blades means more tip speed, which increases drag once it reaches transonic speeds; also, the longer blades means longer landing gear for tip clearance or more clearance between two propellers and/or fuselage. This increased structural weight is unacceptable as leads to a vicious cycle. An extreme case of this is the F4U Corsair, which had an inverted gull wing to accommodate the huge three bladed propeller required for the extremely powerful engine.
Increase the rpm The problem is again the tip speed, which can increase drag significantly at high speeds.
Redesign the blade with more camber Again, the blades are usually at their optimal aerodynamic efficiency; increasing the camber may lead to less efficient blades.
Increase the chord This increases the solidity, improving efficiency; however, this leads to increased interference between the blades, which is again bad.
Increase the number of blades This is usually the solution adopted for reasons above. The blades may become inefficient, but the system is able to produce more thrust with minimum impact (like maintenance etc.). As Hartzell says,
...efficiency doesn’t propel the airplane, thrust does
A good example of the effect of the engine power on the number of propeller blades can be seen in the case of Lockheed Martin C130 Hercules.
The initial model, the C-130A used a three bladed propeller to absorb the 4050 shp of Allison T56-9 turboprops.
Source: commons.wikimedia.org
Later models used a four bladed propeller as the engine power was increased to 4590 shp in Allison T56-A-15 turboprops.
Source: planespotters.net
The C-130J Super Hercules uses a 6 bladed propeller to absorb the 4,637 shp from Rolls-Royce AE 2100D3 turboprop.
Source: theaviationgroup.eu
In extreme cases like the Tu-95, contra rotating propellers had to be used to absorb the power from the engines.
Source: airplane-pictures.net
