For obvious reasons, that's the best way of tracking the whereabouts of my luggage. Once the plane lands, it would establish a 3G connection, and I would be able to access its GPS position.
    $\begingroup$ Aside from this being more for travel.SE, your GPS receiver won't do you much good shielded in a closed bag and probably covered by a building (airport) or other bags (transported from plane to airport). I know that isn't your question, but I don't think that is a very good way of tracking lugagge. $\endgroup$ – JustSid Nov 13 '15 at 2:14
  • $\begingroup$ i read about a device sometime back, which does the same thing, i.e. keep track of your luggage. you might do a google search about it. $\endgroup$ – Firee Nov 13 '15 at 7:13
  • $\begingroup$ There are apps that will turn airplane mode off at a particular time. Probably best to give it plenty of leeway in case the flight is delayed $\endgroup$ – TomMcW Nov 13 '15 at 14:56
  • $\begingroup$ Lithium-ion batteries in the cargo hold are a big no-no... $\endgroup$ – Ben Nov 14 '15 at 15:58
10
Your phone must be in airplane mode whether it is in the passenger cabin or cargo hold. In this case the phone will never establish a 3G connection and won't meet your desired use case.
Leaving the phone with cell service on will likely also not solve your problem. Cell phones tend to use a lot of battery trying to connect to a tower when there are none in range. By the time you land your phone may have already shut down from losing power. If the bag is lost it may be deep in the bag handling areas of the airport or some other corner with no cell service and certainly no GPS signal. In all likelihood unless someone mistakenly takes your bag home and decides to charge your phone and turn it back on this plan of yours will not work.
