What is the reason behind that most (or many) military transport aircraft use turboprop engines?
1 Answer
It depends on the main purpose of the mission. For example, for long haul flights, carring many pallets, they will use probably the turbo jets, because they have more endurance, and normally they will land on longer runways.
1$\begingroup$ You may provide some contexte and links, and develop you answer. See this help page for more information. $\endgroup$– Manu HNov 12, 2015 at 13:34
$\begingroup$ Also, you can edit your previous answer to include more information instead of creating a new, nearly equally short, one. $\endgroup$– FreeManNov 12, 2015 at 19:44
