Will the lift coefficient (Cl) and drag coefficient (Cd) I obtain by using software simulations or subsonic wind-tunnel tests be the same as on an actual aircraft while cruising? Or will there be some error?
    $\begingroup$ There will be some error. I have plenty of experience with computational mechanics, and there is always an inherent error. The question is always whether the error is acceptable given the application, not whether there is an error at all. If unacceptable, you will need a more sophisticated model, either by a more sophisticated model or by obtaining experimental data. $\endgroup$
    – Sanchises
    Nov 11 '15 at 14:10
  • $\begingroup$ Wind tunnel tests usually are "real-world conditions" for all practical purposes. That's why we have them and don't just use CFD for everything. $\endgroup$
    – reirab
    Nov 11 '15 at 16:26
  • $\begingroup$ Also with wind-tunnel testing there will be differences coming from (possibly) different Reynolds numbers, different Mach numbers, different geometrical scaling, blockage effects, support effects etc. That's why there's still full-scale flight testing :) $\endgroup$
    – ROIMaison
    Nov 11 '15 at 18:17
  • $\begingroup$ There will be lots of errors due to the technics involved (method itself), and then there are the errors caused by configuration differences (aero configuration of the real flying thing (that are not modeled or are modeled with different geometries), and weight of the real thing, etc), and finally from the time the aircraft design is frozen till entry into service there are design changes which may influence the aero characteristics. That's why you fine tune the approximations during flight test phase with a prototype aircraft. $\endgroup$ Nov 11 '15 at 19:12
  • $\begingroup$ As mentioned, there are differences between CFD, wind tunnel and the real world. This is very evident in Formula 1, where the first practice session is used by the teams to do real world testing of aerodynamic pieces that they think will work based on the CFD & WT. Some teams spend an entire season struggling to figure out why what works in the lab doesn't work on the track. $\endgroup$
    – FreeMan
    Nov 12 '15 at 19:22
It depends.
In computational fluid dynamics (CFD) there are limits for the calculation of turbulent flow. This means that large flow separation cannot be modeled precisely; especially its time-dependent characteristics are computationally much too complex to be modeled. Instead, statistical methods must be used.
For attached and far-field characteristics the methods are refined enough to yield very accurate results, so much that what had historically been studied in wind tunnel tests or only on the finished aircraft can now be calculated with confidence up to hypersonic speeds. Errors still exist - after all, if the geometric model does not include the manufacturing irregularities of the real aircraft, the results will not be in total agreement, but close enough for engineering purposes.
In wind tunnel testing you cannot expect the same results as long as the Reynolds number and Mach number are different from the real thing. This is adjusted with correction factors, and again the results become good enough for engineering purposes. Cryogenic wind tunnels even remove this restriction, but are very expensive to build and operate, because they run with pure nitrogen at very low temperature and several bars of pressure. Small errors remain, because all the details of the real aircraft cannot be modeled in a wind tunnel model and their ratio between dynamic pressure and stiffness cannot be adjusted for all flow conditions, so aeroelastic effects will remain different.
Windtunnel tests are still valuable for predicting forces in post-stall conditions and for calibrating new CFD codes. Most of the operational envelope can then be covered with CFD. The combination of both is enough to predict the force coefficients with confidence, and only aeroelastic effects and details of the stall behavior might turn out slightly differently than anticipated from tests.
As @TrebiaProject points out in the comments, CFD can help with the corrections. The influence of the sting the model is mounted on would be a primary example. CFD can help to understand its influence and correct for it. This makes CFD complementary, so both techniques will lead to better results if combined correctly.
  • $\begingroup$ In my experience, CFD only works great if you know the answer apriori. Once you've performed some wind tunnel test, you can always finagle CFD to match it; but if you're starting from scratch, CFD is almost always off (if not dead wrong). On the other hand, CFD is a great tool for generating data for design iterations or off-condition corrections. $\endgroup$
    – JZYL
    Jul 25 '20 at 0:25
  • $\begingroup$ @JZYL May I politely disagree? CFD is not trivial to use, but when you know what you are doing it saves a tremendous amount of time and the wind tunnel only gives a final confirmation of all that CFD work. Next, with CFD you can look into every corner of the flowfield in details that would be impossible in the wind tunnel. You use the wind tunnel to calibrate the calculation but what really enlightens you is the numerical result, not the tunnel data. $\endgroup$ Jul 25 '20 at 6:55
    $\begingroup$ Windtunnels also have the challenge of corrections due to supports and attachments of the models. Those corrections can be predicted using CFD. WindTunnel and CFD are today complementary. Wind Tunnels provide high number of flying conditions meanwhile CFD provides high level of details for each solution. On top of what is described above. $\endgroup$ Jul 25 '20 at 23:20
  • $\begingroup$ @TrebiaProject.Thank you! Couldn't agree more. $\endgroup$ Jul 26 '20 at 5:24
