This article from 2013 states that about 30 parts of the Dreamliner are 3-D printed, mostly air ducts and hinges.
I wonder
  1. what other parts are produced by direct manufacturing?
  2. why it was deemed essential to resort to printing them instead of molding/stamping?
I know this sensor for the GE90 engines was one of the first parts to be approved for use on aircrafts and was 3D printed. This was important since it was a critical engine part. I don't think interior trim parts are held to the same standards (or need to comply with as stringent regulations) as engine components.
It may just be a simple case of it being cheaper to 3D print them. Extruding/molding/final machining of complex parts can be time consuming and complicated. If you can 3D print it faster/cheaper or both, than you can make it with traditional methods then printing will win out.
In some cases what may seem like one part could actually be a few parts, bolted, riveted, or welded together. Boeings space division seems to be working on this as well and are able to reduce part complexity by 3D printing parts, according to one of their engineers
“We can build fewer and more complex parts up front, which in turn reduces assembly time and costs,” Wilson said."
For what its worth GE was able to 3D print a whole jet engine recently.
(source)
Depending on how you look at it there is an argument for composite structures being in a way direct manufacturing since you are making an entire piece (say a whole wing) in one shot instead of riveting a bunch of sheets of metal to a wing structure or pulling fabric over a steel frame (although you are usually pulling fabric over a foam mold in a sense).
Another example of printed parts is electronics covers.
It wasn't necessarily "essential" to use 3D printing, but economical or beneficial versus other choices. For aircraft parts, 3D printing has a few advantages over more traditional methods of manufacturing:
  • Much less delay for manufacturing. A new part can be designed and then 3D printed very quickly. Traditional methods need much more time to create tooling for each new part. If you are delaying a product worth millions, time is important, and the faster method will have a big advantage.
  • There can also be less cost in manufacturing. The cost of initial tooling for a part only pays off in the long run if many parts are produced. A 3D printer can potentially make many different parts, with minimal added expense to make a new design.
  • The design can also be made more efficient. 3D printing can create shapes and designs that are not practical with traditional methods. This can reduce the weight and complexity of parts.
