Looking at this crash - wiki - my question came up - are there passanger planes, which have real time view of external components like engines, wings and so on, which can eventually help pilots understand what part malfunctioned ? If not what would be a good reason ?
Edit: Please note that I am not looking for planes with cameras used for manoeuvring, but for such pointed towards critical components e.g. engines, so if there is a visible fault (smoke coming out of the engine) the pilots would know the exact failed component/part of it.
    $\begingroup$ I'm fairly certain that ability would actually be detrimental to the work of flying the plane. There are many documented cases of pilots landing planes with what look like horrible damage. If they saw the damage it could stifle their ability to perform checklist tasks to determine if the plane CAN fly, regardless of the damage incurred. $\endgroup$ – CGCampbell Nov 9 '15 at 15:33
  • $\begingroup$ @Simon not exactly, check out my edit :) $\endgroup$ – Phantomazi Nov 9 '15 at 15:57
  • $\begingroup$ Not a camera, but the Cessna Skymaster push-pull has mirrors so the pilot can see whether the rear engine is spinning or not. $\endgroup$ – GdD Nov 9 '15 at 16:57
  • $\begingroup$ A camera would not have really helped in that accident. The issue was not that it was impossible to diagnose the problem from the available instruments, it was that the pilots failed check all of them properly. $\endgroup$ – Jan Hudec Nov 9 '15 at 17:31
  • $\begingroup$ Maybe the question would be less theoretical if you could provide an example of incident/accident where the camera would have changed the situation and the outcome. $\endgroup$ – mins Nov 9 '15 at 21:30
15
External cameras for diagnosing aircraft issues are not used on any current aircraft. As mentioned in another answer and question, some aircraft do have external cameras, but these are more for maneuvering on the ground.
One reason for this is that cheap, high definition cameras that can stream directly to a monitor in the cockpit are a fairly recent invention. Previously, such an addition would have been fairly heavy and expensive to add to an aircraft. As mentioned, some newer aircraft that have digital cockpit displays do have external cameras for other purposes. However, even in aircraft with cameras, they are generally not used for diagnosing issues.
A lot of aircraft issues, especially with engines, are not readily visible from the outside. Internally placed sensors are still much better at detecting issues. Landing gear in particular may appear to be extended but not locked properly. Pilots are more concerned with how functional something is. Modern aircraft are equipped with hundreds of sensors and these are designed to give the pilots all the information they need about the functionality of the aircraft. These sensors are much more simple and precise than a camera. External cameras may give a misleading picture of the aircraft's state, and decisions lean towards an abundance of caution. Unless there is some extremely obvious discrepancy, it's unlikely that a camera will be trusted over the sensors.
Of course there are still incidents such as fuel leaks and fires that external cameras would help to identify. However, the aircraft sensors should be able to detect these issues once they are serious enough. Pilots also get information from passengers/crew in the cabin, and from external observers in other aircraft or air traffic control. Cameras are also limited in where they can be placed to provide a good view of things, and how well they will perform at night or in bad weather.
There may be a general case for cameras being helpful in identifying issues, but these situations are rare enough that is is hard to justify the expense. If something is enough of a risk that you need to point a camera at it, you're better off just fixing it so it's less of a risk.
    $\begingroup$ If something is enough of a risk that you need to point a camera at it, you're better off just fixing it so it's less of a risk. This. I work on a lot of industrial automation equipment and the only time I've ever really felt the need to have cameras watching things is during process development - it's a tool that can be helpful for ironing out bugs, especially in a fast-paced, agile development environment. For something that has to be as bulletproof as an aircraft, this work had damned well better be done already. The right sensor will always be better than a camera. $\endgroup$ – J... Nov 10 '15 at 1:18
  • $\begingroup$ There's one situation I can think of where I might want a camera: gear's down and the lock indicators haven't come on. Is the light not working, or is the gear not locked? A camera might save you a low pass and some heartburn. And might've saved Eastern Air 401, though that really goes back to a CRM problem. $\endgroup$ – Erin Anne Nov 10 '15 at 1:31
The A380 has a camera mounted in the tail that provides a view of the top of the aircraft as well as the upper surface of the plane. Apparently it's there to help navigate at airports, you can sort of see it here
enter image description here (source)
There seem to be a few other planes that offer this according to this thread
  • A330-200
  • A330-300
  • A340-300
  • A340-500
  • A340-600
  • A380
  • B777-300ER
I'm not sure where this feed is bussed to but I assume they can bring it up on their flight displays.
A great deal can also be seen from out the windows of the plane as well.
Keep in mind that it's only recently that camera and display technology has shrunk to its modern size. Many planes out there were designed in the late 70's or 80's. Having full frame video feeds in that time would have required bulky equipment that costs you weight and power. It should also be noted that cameras like this would be ineffective in clouds with little to no visibility as well as at night (although we are making progress on that front). The outside of a plane is not really lit up that well so a camera would not see much at night.
As for using them in fault procedures this is a mixed bag and in some cases an opinion on if it will help or hurt the situation. For what it's worth the only key surfaces that you can't see through the windows are most of the empennage and the underside of the wings/underbelly of the craft as well as part of the engines. When it comes to the rudder and elevators a camera may help you determine if a control surface experiences an inadvertent deflection or becomes unresponsive to control input. It will also show any surface damage to the unit. Likewise with the wings you will be able to see any damage to the lower parts of the wings, however most control surfaces can be seen through the windows. To play the other side some might argue that cameras would be distracting in an emergency and pilots should not be trying to determine what they can see when they should be flying the plane. Others of course may say that if they can see a control surface is not properly actuating they may be better able to provide the proper correction.
  • $\begingroup$ Fully agree with you about it being a recent technology, but still I think even for flights when there is sufficient light conditions this may be useful enough to prevent possible loss of lives. The main point is that these cameras should show the failing components, instead of point-of-view useful for taxiing, as I doubt this one will be handy in such a situation(feel free to prove me wrong here ! ) $\endgroup$ – Phantomazi Nov 9 '15 at 15:50
  • $\begingroup$ Typo my apologies - edited $\endgroup$ – Dave Nov 9 '15 at 16:44
  • $\begingroup$ I flew with Malaysian earlier this year and the passengers were able to view the feed from this camera! $\endgroup$ – Gusdor Nov 10 '15 at 9:56
  • $\begingroup$ I remember a vivid discussion about the A380 camera when it was proposed, and that some people said it should only be available when not in flight just like a dvd system in a car. I have no idea how the actual decision turned out... $\endgroup$ – PlasmaHH Nov 10 '15 at 10:31
They already do.
A light sensor is a camera which transmits just one pixel of information. The same goes for a thermal sensor, instead of transmitting an infrared thermal image of many thousands of pixels, it only sends one pixel of thermal information each time it cycles.
And that pixel itself could contain many different values. In some cases, it could store lots of information about light and color. And in some other cases, depending on the sensor itself, it could also just store one bit of information, a one or a zero. And of course, not all sensors use the light spectrum. The are various other sensors capable of other things.
Reducing the amount of information to the most relevant part helps pilots avoid cognitive overload, but having less real-time data also makes it easier to record the raw data over the life time of the airplane (or at least until it crashes).
And yes, sensors can malfunction just like cameras can malfunction, but they can also be redundant in their function and more precise in what problems they may be trying to pinpoint. So if one sensor malfunctions, other sensors may be able to double check the same functionality in other ways.
    $\begingroup$ This raises a philosophical question - how many radiation sensors are needed before the array is a camera? $\endgroup$ – Gusdor Nov 10 '15 at 9:58
