I've been reading more about the development of the A-12, which in turn referenced the CL-400 Suntan. I noticed that the engines are located at the end of the wing, rather than integrated with the fuselage or on the midpoint, which is not something I've seen (or at least noticed) on any other aircraft (the closest thing I'm aware of is tip jets on helicopters). What is the design rationale behind locating engines on the end of the wing, and indeed for other locations?
3$\begingroup$ See engine locations in general, and locations far from the fuselage $\endgroup$– fooot ♦Nov 7, 2015 at 19:37
$\begingroup$ The asymmetric thrust of single-engine operation must have been considered and deemed manageable... or was it deemed to be of low enough probability for a military aircraft that it would be cause for bailout? $\endgroup$– Anthony XNov 8, 2015 at 17:53
The Suntan project needed all fuselage space to hold three tanks for liquid hydrogen, so the engines had to be placed somewhere else. Placing them near the fuselage would put them in the range of the fuselage's shock waves. Putting them out on the wing would help with wing bending relief and ensure a clean intake flow. Once they are so far out, you can as well put them on the wingtips, so that they do not cause a pitch-up moment. On the SR-71, the engines were also placed outside the fuselage and into the wing's plane, much for the same reasons.
Keeping the intake flow uniform is paramount for the undisturbed operation of supersonic intakes, and I assume that Kelly Johnson wanted to make sure that the engines would not suffer an unstart when flying reconnaissance missions over hostile territory. With the little experience in supersonic flight in 1955 it was prudent to avoid built-in pitching moments - after all, the supersonic L/D likely was in the single digits, so an out-of-plane engine placement would had produced more moment than on subsonic aircraft.
Hydrogen was selected to achieve the highest possible flight altitude, so the aircraft would be safe from surface-to-air missiles for as long as possible. I initially thought that the wingtip location would enable to cool the hot wing structure by heating up the hydrogen on its way to the engine, but heating was planned to be done with bleed air in a special heat exchanger. Quoting www.history.NASA.gov:
The CL-400 design divided the hydrogen tankage into three sections; the forward tank had a capacity of 67 000 liters; aft, 54 000; and center (sump), 15 000. The two main tanks were kept at 2.3 atmospheres pressure and the sump tank slightly lower for fuel transfer. In the sump was a booster pump, built by Pesco Products, that supplied liquid hydrogen to the engines at a pressure of 4.4 atmospheres. The engines were mounted at the wing tips, which meant that the liquid hydrogen had to pass through a hot wing with surface temperatures up to 436 K. The design provided a vacuum-jacketed, insulated line for this purpose.
Regarding the perceived danger of using hydrogen, www.history.NASA.gov says:
Tests were devised in which tanks containing liquid hydrogen under pressure were ruptured. In many cases, the hydrogen quickly escaped without ignition. The experimenters then provided a rocket squib (a small powder charge) to ignite the escaping, hydrogen. The resulting fireball quickly dissipated because of the rapid flame speed of hydrogen and its low density. Containers of hydrogen and gasoline were placed side by side and ruptured. When the hydrogen can was ruptured and ignited, the flame quickly dissipated -, but when the same thing was done with gasoline, the gasoline and flame stayed near the container and did much more damage. The gasoline fire was an order of magnitude more severe than the hydrogen fire. The experimenters tried to induce hydrogen to explode, with limited success. In 61 attempts, only two explosions occurred and in both, they had to mix oxygen with the hydrogen. Their largest explosion was produced by mixing a half liter of liquid oxygen with a similar volume of liquid hydrogen. Johnson and Rich were convinced that, with proper care, liquid hydrogen could be handled quite safely and was a practical fuel-a conclusion that was amply verified by the space program in the 1960s. At the time, however, Johnson and Rich filmed their fire and explosion experiments to convince doubters.
When work on Suntan started, liquid hydrogen was a laboratory curiosity. Preparing the infrastructure needed for operating the CL-400, the Suntan project led to the building of large-scale liquid hydrogen plants. Their availability paved the way for the cryogenic rockets of the Apollo program!
Interestingly, a similar engine location was selected by the Russian design bureaus Tsybin for their NM-1 and Myasishchyev for their M-50 supersonic bomber in the mid-50s. It was started after news of the US Weapon System 110 (which later led to the XB-70) reached Russia and was similarly cancelled after two prototypes had been built and only one aircraft had flown.
M-50 during display in 1961 at Tushino airshow (picture source). Note the similarity of the Mig-21 and M-50 planform - both originated from the same work done at TsAGI.
Placing the outer engines below the wing would had caused ground contact on rotation. Speaking of rotation: The M-50 had two central gears and the bomb bay between them, and the main gear had to be placed so far aft that the M-50 could not be rotated the usual way with the elevator. So the engineers devised what they called the "galloping bicycle". When the aircraft reached 300 km/h, the forward gear rapidly extended to rotate it to 10°. Placing the outer engines B-58-like below the wing would had required an even longer gear.
The position of the engines on wing is determined by a number of factors:
Aerodynamics: The flow at engine intake should be as undisturbed as possible. The drag should be kept as low as possible.
Safety: Any uncontained engine failure should not affect other components (like fuselage, wing or other engines).
Control: In case of multi engined aircraft, asymmetric thrust due to the failure of one engine should not produce uncontrollable yawing moment.
Comfort: In case of civil aircraft, the cabin noise due to engine should be minimal.
Structural: The location of engines far from the center-line gives beneficial wing bending relief in flight.
Fuel capacity: the location of engines in pods outside the wing frees up space for fuel in the wing.
Maintainability: The engines should be easily accessible for maintenance and repair crew.
The CL-400 had its engines in the wingtips, that freed up the fuselage to carry the fuel. A similar arrangement was found in the Myasishchev M-50
Image from testpilot.ru
Both were designed to be high speed, long range aircraft, with neither fulfilling their requirements.
Another aircraft with wingtip engines was the French Trident, which was expected to be a rocket powered interceptor.
"SO.9000 Trident" by Deep silence (Mikaël Restoux) - Own work (Bourget museum, in France). Licensed under CC BY-SA 2.5 via Commons.
Also, some P-51s were fitted with wingtip rocket ramjets for increasing their speed.
Image from jimbrooks.org
$\begingroup$ The trident is a cool-looking airplane! Is it the angle or are the wings not swept at all? $\endgroup$– TomMcWNov 8, 2015 at 19:13
$\begingroup$ @TomMcW it indeed has straight wings, essentially just slabs of metal. Remember this was built in France just after the war by engineers who had no access to German, US, and British research into high subsonic and supersonic aerodynamics. They were effectively trying to build a supersonic aircraft using 1930s aerodynamics knowledge. $\endgroup$– jwentingNov 13, 2015 at 7:05
