Are there any systems in a manned aircraft which can be controlled by the ATC/ground control.
To be specific, could you name some tested and existing procedures/systems which make it possible to change aircraft dynamics such that it is manipulated from outside the cockpit of the aircraft and the pilot is overridden?
