10
In the aircraft cockpits I've seen, the gear handles all seem to have the same general shape (they look like a little wheel). Is there a reason for this beyond simply making it absolutely obvious that it's the gear handle?
It's required by law, at least in the US. 14 CFR 23.781, Cockpit control knob shape specifies these shapes for the flap and gear controls on smaller aircraft:
For larger (transport category) aircraft, 25.781 specifies the same thing:
As for why those shapes are specified, it's for at least two reasons:
  • The shape resembles the thing it controls, so it's an obvious memory aid
  • The controls are all shaped differently, therefore you can distinguish them by touch alone, without needing to look at them
As others have noted, there have been accidents in the past caused by pilots using the wrong controls, and this is one reason why the FAA decided to do something to standardize them. Parts 23 and 25 also state where the controls should be placed, for the same reason.
The FAA's Airplane Handbook says:
There have been many cases of the pilot mistakenly grasping the wrong handle and retracting the landing gear, instead of the flaps, due to improper division of attention while the airplane was moving.
They recommend - and I was taught - leaving the flaps alone after landing until clear of the runway (unless you have a good reason for retracting them earlier, like a short-field landing), then check and retract them with the statement "flaps identified and retracted". "Identified" in this case simply means that you're sure you have the right control in your hand. Some instructors even avoid touch-and-goes in complex aircraft (i.e. with retractable gear) because they feel the risk of retracting the gear rather than the flaps during the maneuver is too high; they stop and go instead, even if that means taxiing back for takeoff.
    $\begingroup$ i think its important to add that before this regulation went into effect, there were many accidents when the pilot tried to put the gear down or up and used the flap control instead, because the two controls similar in shape and co-located. for example, here's the gear and flap control handles on a DC-3. I can't tell which is which. maam.org/airshow/images/r4d_cockpit_17.jpg $\endgroup$ – rbp Nov 5 '15 at 15:31
    $\begingroup$ @rbp Good idea, I've expanded my answer $\endgroup$ – Pondlife Nov 5 '15 at 16:52
    $\begingroup$ Excellent answer, thank you. I wish the images were a bit better, but they're great none-the-less. $\endgroup$ – Steve Nov 5 '15 at 21:49
    $\begingroup$ @Steve Well, that's the image quality that the FAA has on their website. Good enough for government work, I suppose :-) $\endgroup$ – Pondlife Nov 9 '15 at 16:40
    $\begingroup$ Specifically, it was due to gear retraction of the B-17 and the solution proposed by Alphonse Chapanis en.wikipedia.org/wiki/Alphonse_Chapanis $\endgroup$ – Adam Aug 9 '17 at 18:31
This is the very reason. Cockpit ergonomics are not only to make things easy to use but easy to tell apart. Here is an incident in a smaller plane as a result of flap handle/gear handle confusion. Here is an NTSB report on the same issue with Beech Bonanza
If memory serves this also happened on a bigger plane once (im trying to find the accident report).
There has also been a push to make cockpits at least similar across the board to avoid issues. The best example of this issue has been the difference between American and Russian made attitude indicators which offer the visual appearance of being reversed of each other. You can read about that here.
As for why there is specifically a little wheel on the lever you can check out this discussion over on airliners.net about that very topic.
    $\begingroup$ Isn't the best example the fact that Cessnas and Pipers have the throttle and carb heat levers opposite ways? $\endgroup$ – Dan Hulme Nov 4 '15 at 22:12
