I saw this beacon at an old airport; how and in what situations was it used?
Beacon at Ljunbyhed, ESTL
    $\begingroup$ Please provide attribution for your image. $\endgroup$
    – CGCampbell
    Nov 1, 2015 at 15:53
    $\begingroup$ What airport was this seen at? Are there other pictures? Airport beacons are typically White/Green Rotating units and do not have a red light on top. This may however predate modern convention. $\endgroup$
    – Dave
    Nov 2, 2015 at 2:21
  • $\begingroup$ I took this pic myself at Ljungbyhed, Sweden(ESTL). More pics on request ;) $\endgroup$
    – juni-j
    Nov 2, 2015 at 20:31
It's the airfield identification beacon.
An aerodrome beacon or rotating beacon is a beacon installed at an airport or aerodrome to indicate its location to aircraft pilots at night.
An aerodrome beacon is mounted on top of a towering structure, often a control tower, above other buildings of the airport. It produces flashes not unlike that of a lighthouse.
Airport and heliport beacons are designed in such a way to make them most effective from one to ten degrees above the horizon; however, they can be seen well above and below this peak spread. The beacon may be an omnidirectional flashing xenon strobe, or it may be an aerobeacon rotating at a constant speed which produces the visual effect of flashes at regular intervals. Flashes may be of just a single color, or of two alternating colors.
  • $\begingroup$ Flyer's version of a lighthouse... except it indicates the port, not a hazard to avoid. I've seen these from above, when in a friend's private plane after dark; they definitely do catch your eye and help you plan your approach. $\endgroup$
    – keshlam
    Nov 1, 2015 at 3:09
