My aunt recently was going on a flight home and she boarded the flight, but her flight was delayed due to frost on the aircraft. She noticed this crane like device above the aircraft wing during the removal process. How do they remove frost off an airliner?
  • $\begingroup$ I couldn't find any good tags for this question. If you guys find any tags that would fit with this question then go ahead and add it in, and you probably want to delete my frost removal tag. $\endgroup$ – Ethan Oct 30 '15 at 18:01
  • $\begingroup$ On Youtube: Aircraft Deicing Philadelphia International Airport (and many more linked). $\endgroup$ – mins Oct 30 '15 at 18:18
  • $\begingroup$ @Simon Sort of... Frost can form even on very hot days (due to cold fuel in the wings). While the answers apply, the linked question isn't quite a duplicate, especially since it isn't even always required to remove frost in the first place. $\endgroup$ – Lnafziger Oct 30 '15 at 18:18
Frost is removed through the application of (typically) Type I de-ice fluid (information about de-/anti-ice fluids). Fluid application is generally from a truck with a lift so that the operator can spray the aircraft from above. The fluid is generally hot, diluted with water and under pressure so you'll see lots of steam coming off of the fluid spray. The truck will drive around the airplane spraying the wings, tail and fuselage as necessary to completely remove snow, ice and frost.
Some airports have static mounted de-ice towers that are more like cranes and some operators have automated trucks where there is no operator in the lift and they can do the whole operation from the cab of the truck.
