I want to see if a propeller is bad or good for generating static thrust. This is what I know about the propeller and the engine used to turn it during a test:
Engine shaft power, $P$ = 0.58 hp
Propeller diameter, $D$ = 8.5 ft
Revolutions per minute, $RPM$ = 245
Static thrust, $T$ = 18.75 lbf
Can I calculate the efficiency of the propeller? What is the maximum achievable efficiency?
Additional explanations
The formula I was suggested to use could be exactly what I need. However, using it, I do not get some reported experimental results like:
Engine shaft power, $P$ = 6 hp
Static thrust, $T$ = 66 lbf
Propeller efficiency, $\eta_{prop} \geq 66\%$
Gear efficiency, $\eta_{gears} \geq 85\%$
Doing the calculations: $\eta_{prop} = \sqrt{\frac{T^3}{(P^2 \cdot \pi \cdot \eta_{gears} \cdot \frac{D^2}{2} \cdot \rho )}} = 37.2\%$ which is well below 66%.
    $\begingroup$ Homework question? $\endgroup$
    – Ralph J
    Oct 25, 2015 at 12:50
    $\begingroup$ @Ralph Looks like another question about the Wright brothers. $\endgroup$
    – user11933
    Oct 25, 2015 at 13:00
    $\begingroup$ Why the downvotes with no comments? Seems like a perfectly reasonable aviation question to me. +1 to help restore CAVOK. $\endgroup$
    – Simon
    Oct 25, 2015 at 15:34
    $\begingroup$ Possible duplicate of Is there any equation to bind velocity, thrust and power? $\endgroup$
    – user11933
    Oct 25, 2015 at 22:12
    $\begingroup$ "Bad or good" is opinion. $\endgroup$ Oct 26, 2015 at 10:14
Engine shaft power: P = 0.58 hp, Propeller diameter: D = 8.5 ft, RPM = 245, Static thrust: T = 18.75 lbf
$\eta_{prop} = \sqrt{\frac{T^3}{(P^2 \cdot \pi \cdot \frac{D^2}{2} \cdot \rho )}} = 49.5\%$
where $\rho=1.2 \frac{kg}{m^3}$
So at an efficiency of 49.5% that propeller is rather poor.
Note: I used the formula that relates static thrust to efficiency, power and propeller diameter from here.
    $\begingroup$ It is known that the efficiency of a plane propeller is low at small forward velocities, so just because eff_prop =~50%, when the plane does not move, it does not mean the propeller efficiency will remain the same as the plane speeds up. $\endgroup$ Oct 28, 2015 at 17:05
