48
I've ready many, many times that propellers are not efficient near the speed of sound because it's so hard to get a tip-speed above Mach 1.
Then I came across this:
It's the Tu-95 "Bear", a propeller-driven bomber whose blade tips actually move faster than the speed of sound. This is the only propeller aircraft I've ever seen whose blade tips do this. There were even reports that submarines' SONARs could hear it from a long way off because those supersonic blade tips were so noisy.
And the plane has a range of 15,000 km. That's pretty good, on par with today's huge commercial airliners.
So how can propellers be very inefficient at supersonic speeds, yet something like this is buildable on propeller-power only?
Edit: Here is the main point of my question: It seems that "all my life" I've been told, "propellers are not efficient at supersonic tip-speeds, and this is what drove the industry to jet power." And yet here is this apparent counterexample, the Tu-95. So how is this possible? What am I missing?
Here is a somewhat related question asking if helicopter blades regularly go supersonic. This is another point I've heard many times: heli blades don't do that because that would make them very inefficient. I'm assuming the rotors are effectively governed by the same laws of efficiency as a propeller for a fixed wing aircraft.
Edit: the B-52 was mentioned in comparison so here are some figures:
$$\begin{array}{|l|r|r|r|} \hline \text{Model} & \text{Fuel capacity [L]} & \text{Loaded weight [kg]} & \text{Range [km]}\\ \hline \text{B-52} & 181,610 & 120,000 & 16,230 \\ \hline \text{Tu-95} & 95,000 & 171,000 & 15,000 \\ \hline \end{array}$$
This to me says the Tu-95 is very much more efficient, because it has significantly more weight and significantly less fuel capacity, yet has about the same range.
    $\begingroup$ FWIW, it was the US SOSUS system, en.wikipedia.org/wiki/SOSUS, that could detect the "Bears", not necessarily individual submarines... $\endgroup$
    – DJohnM
    Oct 21, 2015 at 5:44
    $\begingroup$ Long range doesn't necessarily mean it's efficient. It's designed to be a long-range (inter-continental) bomber, so it makes sense that it would have a long range. The U.S. B-52 from the same time period has a slightly higher range at 8,760 nmi (16,230 km,) despite flying significantly faster. That doesn't mean either aircraft was necessarily fuel efficient. $\endgroup$
    – reirab
    Oct 21, 2015 at 6:15
    $\begingroup$ @ROIMaison thanks for showing how to put the data in a table, but please be more careful in the future as the figures for B-52 and Tu-95 were mixed up. I swapped them back. $\endgroup$
    – DrZ214
    Oct 21, 2015 at 7:09
    $\begingroup$ The piston engine tag is erroneous as I believe the Tu-95 uses turboprop engines.. $\endgroup$
    – muskrat
    Oct 21, 2015 at 10:56
    $\begingroup$ The Bear is extremely loud. I understood that the noise was due to the contra-rotating propellers. Each blade on a propeller creates a small shock wave. When you have contra-rotating propellers, the shock waves from the trailing prop intersect the shock waves of the leading prop. Where you have 4 blades on each prop, 4 such intersections occur, simultaneously, 4x / revolution. That adds up to extreme noise levels. Different numbers of blades between the two props would result in lower amplitude (no simultaneous intersections) and higher frequency (possibly above human hearing range). $\endgroup$
    – Meower68
    Apr 11, 2016 at 19:09
73
Yes, propellers have problems at high speed, but if done right, they still have an advantage over turbofans at speeds up to Mach 0.8. Look at the inner engine gondolas of the Tu-95: They are elongated and thicker aft of the trailing edge. This was done to stow the landing gear in them, but also to area-rule the aircraft. The Tu-95 applies knowledge that was gained only in the early jet age. This, of course, also explains the swept wing.
Next, it uses contra-rotating propellers which spin very slowly (just 750 RPM). By having two coaxial propellers spinning in opposite direction, the efficiency at high speed is improved. The first propeller pre-swirls the flow so the flow conditions on the second propeller are more favorable for thrust creation.
The tips of the fan blades of a modern turbofan also move at supersonic speed, so the supersonic propellers on the Tu-95 do not create a direct disadvantage. By keeping the relative thickness of the blade near the tip low, the drag increase can be kept at tolerable levels. But make no mistake: Supersonic flow adds wave drag, and especially around Mach 1 the zero-lift drag coefficient of everything which moves through air has a maximum. It would make the Tu-95 even more efficient if it would fly at a lower cruise speed where the propeller tips are still subsonic, but Tupolev wanted to push the design to the highest useable cruise Mach number.
What you learned about propellers and jets is not wrong, but it is not a black and white world, either. Airliners use jet engines to fly at the highest cruise speed possible, but at the cost of higher fuel consumption. If they would restrict themselves to lower speeds, plenty of fuel could be saved. But too few people would book these flights, because on intercontinental routes they will take noticeably longer. Note that turboprops are still used in regional air traffic, and even the regional jets have lower flight speeds than the intercontinental jets.
Now to the efficiencies of engine types:
  1. Piston engines are the most fuel efficient aviation engines. Their drawback is a constant power output over speed, so that thrust is inverse to speed. This helps for acceleration at take-off, but limits maximum speed. A modern piston engine uses 240 g of fuel for providing 1 kW of power over one hour: 240 g/kW-h. Diesel engines use as little as 220 g/kW-h. This number is already true for the old Jumo 205, among the first aviation diesel engines in operation 80 years ago.
  2. Turboprop engines are next, and their power increases a little over speed due to ram pressure (which will raise the internal pressure in the engine by approx. 30% at Mach 0.8). Their power-specific consumption is about 300 g/kW-h but goes down with increasing size, so the biggest turboprops approach piston engine levels of efficiency.
  3. Jet engines are less efficient than both, but are better for flying fast and high. Their thrust drops even less with speed, so the better basis for expressing consumption is thrust, not power. The typical fuel consumption of a modern jet engine (GE-90) is 30 grams of fuel per Newton of thrust over one hour (30 g/N-h) when run stationary, and twice that in cruise at Mach 0.85. Modern Military jet engines achieve 80 g/N-h at take-off and have roughly constant thrust and specific consumption over speed. Since most innovation happens on turbofans these days, the most modern turbofans again approach piston engine levels of efficiency, but if you compare the same technological standard, they are less efficient than their piston and turboprop contemporaries.
In all cases, thrust is created by accelerating a mass of air backwards. The general equation for propulsive efficiency $\eta$ is $$\eta = \frac{v_{\infty}}{v_{\infty}+\frac{\Delta V}{2}},$$ where $\Delta v$ is the speed increase of the mass of air due to that acceleration. This formula shows that it is better to accelerate a big mass of air only a little than a smaller mass by a lot. Propellers do this and for that reason offer the best efficiency. Turboprops use less efficient, but lighter gas turbines for creating power, but retain the efficient propeller. Civilian turbofans try to increase the mass of air by increasing their bypass ratio, and only the military is using the least efficient types with bypass ratios below 1, because they are the best choice at supersonic speed.
Below you see a plot of the thrust-specific fuel consumption in cruise condition of different engine types over their bypass ratio. The inverse relation is easily visible.
Plot of thrust specific fuel consumption over bypass ratio
Plot of the thrust specific fuel consumption in lb of fuel per lb of thrust per hour of different engines over the logarithm of their bypass ratio (picture source).
To make a comparison between piston and turbofan engines possible, let's compare fuel consumption at take-off. The formula for static thrust of a propeller is $$T_0 = \sqrt[3]{P^2\cdot\eta_{Prop}^2\cdot\pi\cdot d_P^2\cdot\rho},$$ where $P$ is the shaft power, $d_p$ the propeller diameter and $\rho$ the air density. For our example, we use a four-bladed prop of 3.4 m diameter and an engine with 1111 kW power. Its static thrust is 10.727 kN when we assume standard atmospheric conditions and a prop efficiency of 85%. The fuel flow will be 266.6 kg per hour, and relative to thrust this is 24.8 g/N-h or just 80% of that of a modern turbofan.
I wonder if even the enthusiasts could guess what airplane I used, because I obfuscated it by using those unfamiliar metric units. I guess nobody will argue that it is not optimized for fast flight, so this comparison should also hold for the Tu-95, for which I have less data available.
Here follows the requested expansion on propeller tip speeds. Thanks to the excellent comment by @JanHudec not much is left to say: The propeller diameter is 5.6 m and their speed is 750 RPM, so the circumferential component is $5.6 \cdot \pi \cdot 750 / 60 = 220 m/s$. Add to this the cruise speed of Mach 0.67 (taken from this site — others list quite incredible numbers) at altitude, where the speed of sound is 295 m/s. Mach 0.67 equates there to 197.65 m/s, and vector addition gives 295 m/s for the propeller tips, exactly Mach 1.0. This means that the propeller is subsonic over its whole span.
But the top speed is quite a bit higher. Thanks to the excellent work of Ferdinand Brandner and his team back in the Fifties the NK-12 engines developed already 12,000 horsepower back then, and their power output has since been raised to 14,795 HP. This allows a top speed of Mach 0.82, and now the tip speed comes out at 327 m/s or Mach 1.08 — mildly supersonic. This means that the outer 30% of the propeller experience supersonic flow.
I fail to find a source for the range figures you list in your question. Again I refer to this site: It is 7,800 miles or 12,552 km at a cruise speed of 400 knots or 179 m/s which equals Mach 0.606 at altitude, resulting in Mach 0.96 for the propeller tips. Therefore, it seems the best range is reached with subsonic propeller tips.
  • $\begingroup$ Thank you for this data but could you please add more about propeller tip speed? I edited the OP to emphasize that supersonic tip speeds are supposedly very inefficient and that's where my question comes from. Also, please be more careful when editing my data into a table. The Tu-95 and B-52 had mixed up figures; I swapped them back. $\endgroup$
    – DrZ214
    Oct 21, 2015 at 6:56
    $\begingroup$ @DrZ214: I did not edit your question; I had all hands full with my answer. $\endgroup$ Oct 21, 2015 at 7:01
    $\begingroup$ @steveverrill, presumably the 334 m/s would be total magnitude of velocity of the propeller tips including the forward component (where did you get the number, I don't see it in the answer nor on the wiki and it is not speed of sound, which is just around 300 m/s at FL350). At maximum speed 255 m/s the orbital component $\sqrt{334^2-255^2}$ is only 217 m/s and 217/78.5 is just 2.76 m. $\endgroup$
    Oct 21, 2015 at 14:14
  • 13
    $\begingroup$ "Diesel engines use as little as 200 g/kW-h" Pfft. Volkswagen can use way less than that! Oh, wait... $\endgroup$ Oct 21, 2015 at 15:28
    $\begingroup$ @steveverrill, speed of sound is a function of temperature. At average (ISA) temperature at FL350, the speed of sound is 301 m/s. It does not get much lower than that, because temperature only decreases up to tropopause and that is not much higher. But of course the important point is that the tips are supersonic when the forward speed is added. $\endgroup$
    Oct 22, 2015 at 5:04
This is not a Tu-95 specific answer. Keep in mind that a propeller produces force in the same manner as an airplane wing. Subsonic and supersonic wings both produce lift, though using very different design profiles. I would get a good, close look at the propeller to see how the tip area is designed. It may be diamond-shaped, like a supersonic airfoil, or it may be very flat, where the function is not lift, but to reduce vortex energy loss, like that of newer commercial aircraft. As long as the supersonic portion of the propeller does not have the profile of a subsonic airfoil, it will not produce the undesirable effects.
It is actually not unusual for tip speeds to go supersonic. In fact, just about every modern turbofan does it at high thrust settings. Next time if you take a plane, sit at a window seat ahead of the engines where you can "see" the fan blades. During take off you will hear an unmistakable buzz from the fan. That is characteristics of supersonic tip speeds. You will also notice that the latest design have a sudden reverse sweep on the blades near the tips. That is for shock mitigation.
