13
In the attached area of the sectional chart we see restricted areas R-2101 and R-2102. Also covering that general area is a circular, thick, dashed magenta line. There's a notice there that I assume corresponds to it, but I wasn't familiar with this marking before I saw it. I glanced at the Aeronautical Chart User's Guide but didn't see a reference. Anyone know what's happening here?
sectional thick dashed lined
10
The Atlanta sectional near KANB, KASN, and KPLR gives a hint:
FOR REASONS OF NATIONAL SECURITY
PILOTS ARE REQUESTED TO AVOID FLIGHT
AT AND BELOW 5000’ AGL IN THIS AREA
It is called a National Security Area, which FAA’s training ALC-42: Airspace, Special Use Airspace and TFRs describes as follows.
National Security Areas
National Security Areas consist of airspace of defined vertical and lateral dimensions established at locations where there is a requirement for increased security and safety of ground facilities. Pilots are requested to voluntarily avoid flying through the depicted NSA. When it is necessary to provide a greater level of security and safety, flight in NSAs may be temporarily prohibited by regulation under the provisions of 14 CFR Section 99.7. Regulatory prohibitions will be issued by System Operations, System Operations Airspace and AIM Office, Airspace and Rules, and disseminated via NOTAM. Inquiries about NSAs Inquiries should be directed to Airspace and Rules.
Example — National Security Area near Pueblo, Co. and request to avoid flight at and below 3000’ AGL.
National Security Area near Publeo, Colorado
Wikipedia gives a brief description.
In United States aviation, a National Security Area is a designated airspace through which flight is discouraged for reasons of national security.
Flight through NSAs is not prohibited and no special advance clearance or authorization need be obtained to enter them. However, pilots of aircraft are strongly encouraged to either stay clear of NSAs or obtain prior authorization to pass through them in order to reassure the controlling agency that no threat to national security exists.
NSAs are a compromise between normal airspace and restricted or prohibited airspace. NSAs can be temporarily converted into restricted airspace by NOTAMs.
On VFR sectional charts, NSAs are delimited by a heavy dashed magenta border and a special notation.
The thick dashed magenta line indicates a National Security Area.
National Security Areas indicated with a broken magenta line national security area dashes and Special Flight Rules Areas (SFRAs) indicated with the following symbol: sfras , consist of airspace with defined vertical and lateral dimensions established at locations where there is a requirement for increased security and safety of ground facilities. Pilots should avoid flying through these depicted areas. When necessary, flight may be temporarily prohibited.
The answer is in the Aeronautical Chart User's Guide, I just initially overlooked it.
aero chart user's guide
enter image description here (source)
Apparently there are "National Security Areas" which are marked with a dashed magenta line. Here is the description from the guide:
National Security Areas indicated with a broken magenta line and Special Flight Rules Areas (SFRAs) indicated with the following symbol: , consist of airspace with defined vertical and lateral dimensions established at locations where there is a requirement for increased security and safety of ground facilities. Pilots should avoid flying through these depicted areas. When necessary, flight may be temporarily prohibited.
  • $\begingroup$ Sounds reasonable, but I was asking for the sake of utilizing the chart in general, not in a way specific to this area. This might make a better comment. $\endgroup$
    – ryan1618
    Oct 20 '15 at 18:23
  • $\begingroup$ @RyanBurnette I updated my answer with more details. $\endgroup$ Oct 20 '15 at 18:26
  • $\begingroup$ I am familiar with both restricted and prohibited areas. The thick dashed line I'm referring to is neither. $\endgroup$
    – ryan1618
    Oct 20 '15 at 18:29
  • $\begingroup$ The "R-2101" marking seems to be pointing at the blue hatched area nearby, not the red circle. R-2102 is the larger hatched area above it. $\endgroup$
    – Random832
    Oct 20 '15 at 18:31
  • $\begingroup$ Hmm, right, I have updated my answer, apparently it is a "National Security Area" which means they have alien bodies there or something. $\endgroup$ Oct 20 '15 at 18:33
