11
Some fairly busy airports that you would expect to have Class B or C airspace have class D airspace at the airport and normal class E and G airspace around that. In addition, they have an area drawn on the chart with similar dimensions to a class B or class C airspace area but they are labeled as Terminal Radar Service Area (TRSA). What is a Terminal Radar Service Area (TRSA) and what are its operational requirements?
TRSA
A good explanation of a Terminal Radar Service Area (TRSA) can be found in the Aeronautical Information Manual 3-5-6.
TRSAs were originally established as part of the Terminal Radar Program at selected airports. TRSAs were never controlled airspace from a regulatory standpoint because the establishment of TRSAs was never subject to the rulemaking process; consequently, TRSAs are not contained in 14 CFR Part 71 nor are there any TRSA operating rules in 14 CFR Part 91. Part of the Airport Radar Service Area (ARSA) program was to eventually replace all TRSAs. However, the ARSA requirements became relatively stringent and it was subsequently decided that TRSAs would have to meet ARSA criteria before they would be converted. TRSAs do not fit into any of the U.S. airspace classes; therefore, they will continue to be non−Part 71 airspace areas where participating pilots can receive additional radar services which have been redefined as TRSA Service.
These airports can't be redrawn as class B or class C airspace so they became TRSAs. The airspace at the airport is class D and the airspace in the TRSA is usually class E. The operational requirements are no different than any other class E or class D airspace, but aircraft are encouraged to avail themselves and participate in the TRSA when inside its bounds.
It should also be noted that many TRSAs have their own approach control.
    $\begingroup$ Note also that many (but not all) TRSAs have their own approach control like a Class C airport. $\endgroup$
    – NathanG
    Oct 18, 2015 at 17:45
    $\begingroup$ @NathanG many Class Ds have their own approach control as well, particularly in the Western states, e.g. ASE, BIS, CPR, FSD, FSI, GTF, MIB, ROW, RCA among others. Military airfields are particularly likely to be Class D but have their "own" approach control $\endgroup$
    – randomhead
    Mar 1, 2021 at 3:15
A TRSA is an area where pilots have the option of receiving Radar service in a location which has not qualified as a Class C or Class B. As mentioned in @ryan1618's answer, a TRSA does not change the classification or regulatory nature of the airspace.
I had the creation and operation of TRSAs described to me at an Oshkosh forum by an airline captain. He explained it something like this:
A TRSA comes about when a radar system is upgraded, and the older unit is appropriated by a congressman for his home district. He gets it installed at his local Class D airport to the delight of the airport and tower managers. > When calling the designated approach control, if a pilot is not interested in having the controller tell him what to do, he need only say "negative radar service." If inbound to land at the delta airport, they may call the tower and hear a voice remarkably like that of "approach control"
If I were a Class D tower operator. I would think it was cool to have radar coverage at my airport, and it might make me feel like a big-shot to act like I was a TRACON facility. Indeed, it may even be a safety enhancement and provide a training opportunity to the tower controller.
In my experience, there are some radar equipped Class D airspaces which operate like this without having a TRSA charted. A clue lies in the existence of an approach frequency in the chart supplement.
See:
  • KFSD Sioux Falls, SD
  • KFLO Florence, SC
  • $\begingroup$ Interesting stuff. Thanks. $\endgroup$
    – ryan1618
    Apr 30, 2018 at 4:06
