What kind of damage does the ejection process do to the inside of a cockpit or to the aircraft in general?
If ejection were accidentally triggered on the ground (i.e. the ejection wouldn't be followed by a hull damaging/destroying crash), would the damage be minimal enough that it could be flown again by simply installing a new seat and canopy, or would it have to go through a major inspection to ensure no additional damage was done to instruments, wiring, etc?
    $\begingroup$ This question is not about aviation, since none of the ideas you mention are possible. If you were to edit to simply ask what kind of damage does ejection do to the cockpit, it might be answerable. $\endgroup$
    – Simon
    Oct 15, 2015 at 7:55
  • $\begingroup$ I second @Simon's comment here, this is very hypothetical because you would not be able to hold onto the aircraft in the first place, let alone reach inside or open the canopy from outside. Rephrase the question to the final part of the aircraft being maneuverable after ejection and it can be salvaged. $\endgroup$ Oct 15, 2015 at 8:04
  • $\begingroup$ Fair enough. Thanks. $\endgroup$
    – isanae
    Oct 15, 2015 at 8:08
    $\begingroup$ Hypothetical, yes, but the original question was more fun. People could have considered the actual technical part "can a plane be controlled after ejection / what damage does the plane go through during ejection" instead of being so uptight! $\endgroup$
    – iamserious
    Oct 15, 2015 at 14:56
    $\begingroup$ @isanae So edit your question to clarify - as you've worded it here in comments this sounds like a clear and answerable question. $\endgroup$
    – J...
    Oct 15, 2015 at 19:08
5 Answers 5
10
I'm going to interpret safely as meaning successfully. Ejections mean safety has gone out the window - literally.
There was a case in the Vietnam War where a pilot continued to fly his heavily damaged F-4 after his RIO (back seat radar operator) ejected. He managed to keep it together long enough to get back over friendly territory before ejecting himself. Note, this was an interview I saw some years ago, I haven't been able to find a link to post.
In this case the airplane had been hit badly enough that landing was not going to happen, however if the RIO had ejected accidentally or the airplane less damaged then a safe landing would have been possible. So yes, flying has been done and landing is entirely possible after someone has ejected.
    $\begingroup$ There is similar story recalled here which has a landing after RIO ejection. $\endgroup$
    – eis
    Sep 18, 2017 at 20:18
The first test with ejection seats were performed in 1942 in Sweden with a Saab 17 and in Germany in 1941 with a Junkers 87 and in 1943 with a Heinkel 219 and Heinkel's pneumatic seat. Of course, then it was not the pilot who ejected but his back seater, but the aircraft did not need much modification for the tests. In each case, the pilot performed an uneventful landing after the test flight.
Saab 17 ejection sequence
Heinkel 219 during ejection seat trials
Saab 17 (above, source) and Heinkel 219 (below, source) during ejection seat trials.
To enable someone to fly the aircraft home after an ejection requires two conditions:
  • The second seat must be equipped with flight controls
  • The ejection sequencing is switched off, so the seats can be activated independently. Normally, triggering the sequence from either seat will eject all occupants.
It is exceedingly rare that both conditions are true in a modern combat aircraft. There have been a few cases where a crew member flew an aircraft to a successful landing after the pilot bailed out, but I know only a single case where the bail-out was done by ejection seat. It was a Boeing B-47, and the YouTube link is to a re-enactment of this B-47 flight in which one observer, who was also a trained pilot, took over after the crew had bailed out due to a fire in the electrical installation.
Read the last of the stories from this page for one accident in which everyone but the pilot ejected from an S-3 with a stuck nose wheel, and the pilot later performed a safe landing.
I guess you are concerned about the damage done by an ejection. The firing of the rockets happens in the rear part of the now very well ventilated cockpit and is a very brief event, so the flight controls and instrumentation should be in working order after an ejection. However, after the event nobody will be there to take over, and there is no way another crew member will be able to take over unless he/she has his/her own set of controls.
There have been cases of inadvertent ejection seat activations by mechanics on the ground. When this happens, a new ejection seat is needed, the shear pins and in most cases the canopy need replacement. After that, the cockpit area needs to be checked and cleared. But the airplane will return to service.
Fun fact: The XB-70 had ejection capsules to make ejection at supersonic speed possible and to protect the pilots in case of pressure loss. Life support systems and a minimum set of flight controls were duplicated inside the capsule, and the pilot could continue to fly the aircraft down to a safer altitude after initiating the encapsulation sequence. Only then he would trigger the ejection.
  • $\begingroup$ And it would be very difficult to fly with no seat! $\endgroup$
    – Simon
    Oct 15, 2015 at 12:34
  • $\begingroup$ "the flight controls and instrumentation should be in working order after an ejection". Can you confirm that the ejection is not actually damaging anything vital? If the ejection happened on the ground by mistake, could a pilot then enter the cockpit and fly the plane? Is there anything missing (attached to the seat maybe?) or broken that would prevent the plane from taking off? This is my actual question and I would accept this answer. $\endgroup$
    – isanae
    Oct 15, 2015 at 19:19
  • $\begingroup$ @isanae: Your question makes it sound as if you want to land after an ejection happened. Again, it is irrelevant whether all controls are still in place because nobody will be in the cockpit. If someone flies the plane home, he will sit in a different place with his own set of controls. If ejection happens on the ground, the plane needs several days of care before it can be declared flight ready. If somebody brings a chair and tries to fly without harness or canopy, he will be able to do so but needs to restrict his flight envelope severely. $\endgroup$ Oct 15, 2015 at 19:44
  • $\begingroup$ "If somebody brings a chair and tries to fly without harness or canopy..." This is my question. I want to know the damage done to the cockpit. I understand that the plane would normally have to be repaired. I'm asking whether it's possible to put a chair in the cockpit and fly the thing. $\endgroup$
    – isanae
    Oct 15, 2015 at 19:56
    $\begingroup$ @isanae: Normally no, no sane person would do this unless you point a gun to their head. In a desperate situation when this is the only way out, then yes. $\endgroup$ Oct 15, 2015 at 21:16
The fighter can remain airworthy (in the technical sense not in the regulatory sense) after ejecting.
For example the cornfield bomber made a belly landing onto a field after the pilot ejected.
Martin Baker uses (or used, it may have been retired) a modified Gloster Meteor to test ejection seats. The aircraft is piloted, with the seat being in a separate area behind the cockpit.
This aircraft is definitely reusable, it's been used to test ejection systems many times.
So yes, it is possible to design an aircraft in such a way that it can be flown after an ejection of (one of) its ejection seat.
Of course in case of operational ejections these are usually done after the aircraft has sustained enough damage that it can't be flown anyway, so having it flyable after ejection isn't a high priority. And without the crew on board it becomes even less of a priority, as the crew are the ones flying it in the first place.
  • $\begingroup$ After reading this reply, I checked the facts, and indeed, two out of the five remaining airworthy Meteors (WA638, WL419) are indeed (as of 2013) still used in "active service" that way, 70 years after introduction of the type. That's just amazing, and worth a tipping of the hat. $\endgroup$
    – DevSolar
    Oct 28, 2015 at 11:01
There was a case when Soviet MiG-23 was flying for more than 500 miles after ejection of pilot.
https://en.wikipedia.org/wiki/1989_Belgian_MiG-23_crash
  • $\begingroup$ Need to have more details in the answer, rather leaving link to reader. $\endgroup$
    – Lucky
    Oct 16, 2015 at 3:17
  • $\begingroup$ @Lucky A MiG-23 got in trouble over Poland, pilot ejected. The aircraft flew on (presumably on automatic pilot) until the fuel ran out and it crashed in Belgium. $\endgroup$
    – jwenting
    Oct 28, 2015 at 11:08
