With the new-age technologies and cutting-edge composite materials etc available currently, is it possible that biplane and triplane designs will make a comeback in the near future?
$\begingroup$ Related $\endgroup$– PondlifeOct 10, 2015 at 14:39
Biplanes (and triplanes) became (nearly) extinct not because high strength materials (like composites) were not available, but because they became available.
One of the major reasons for use of biplanes in the early days of aviation was that the materials available were of insufficient strength for the (wing) designs used.
The major disadvantage of biplanes (or triplanes) is aerodynamic- it produces a lot of drag compared to the monoplane and the wings interfere with each other.
So, the biplane was an (aerodynamically) inefficient solution to a structural problem. As higher strength materials like Aluminum became widespread, the biplanes fell out of favor.
While they can be revived, I don't see why someone would do that, except for nostalgia (or some special uses, like aerobatics).
There are some companies who manufacture or restore biplanes, but they usually don't use (modern materials like) composites, though modern avionics are used.
7$\begingroup$ Biplanes can still see some (limited) use as bush planes: a much shorter wing can be helpful if you need to land in a narrow forest clearing, and they also have the advantage of good handling at low speeds (the AN-2, for example, which is still widely used today), but it's still a fact that they fulfill only special roles today, and not seeing more use is not because of the lack of technology. $\endgroup$– vszOct 10, 2015 at 16:59
2$\begingroup$ @vsz: Part of the reason we don't widely use biplanes for bush planes is also because of advances in material science. Today planes can be built light enough with an engine powerful enough that they can have wingspans even smaller than WW1 era biplanes and yet only need a single wing. The Zenith CH 750 is a good example of this. Another good example is the Cri-cri $\endgroup$ Oct 29, 2015 at 2:40
No.
Biplanes were the best way to take to the air in the early days because people had not wrapped their minds around the concept of a thick wing. All early aircraft used very thin airfoils, and a biplane produced a very lightweight and strong wing. Materials, by the way, had nothing to do with this, so the use of modern composite materials will not change the situation.
But a biplane does have advantages: If you
- want the fastest possible roll rate,
- a compact airframe,
- want to fly slowly,
- have little need for payload,
a biplane will be the right solution. However, as soon as the plane is used to earn revenue by transporting goods or people quickly and efficiently over long distances, the monoplane is by far the better solution.
Contraptions like the Blériot type 67 will never be built again (except maybe for entertainment).
Blériot type 67 bomber (picture source). Note the very thin wing airfoils.
On the other hand, for flying fun an EAA Biplane is hard to beat. And it is super easy to build.
EAA Biplane P2 (picture source). This design is possible with any aviation-rated materials.
Highly unlikely.
- The most efficient way to increase an aircraft's efficiency at converting thrust to lift is by increasing the amount of air that it is able to use. That's increasing the wingspan.
- It's less efficient to try to get more lift out of air that we are already using -- that's high-lift devices and stacked wings.
The increase in materials is what allowed us to get away from less-efficient methods like biplanes.
On the other hand, a particular wingspan constraint can drive development of multi-planes, as in aerobatics, where the violent forces are betetr resisted by shorter wings.
So perhaps there will continue to be niche applications, but I do not see any economical driver for multi-plane designs, and economics is what makes planes fly in any quantity.
Biplanes long survived in two niches. One was light weight for slow flying where the drag penalty is small, such as agricultural crop-spraying aircraft and ultralights. The other was where extreme maneuvrability demanded a compact layout but there was no need for ultimate speed, such as competition aerobatics.
Eventually modern materials came along and even these niches died out. When Paul MacCready designed his Gossamer Condor and Gossamer Albatross man-powered aircraft, he considered both braced biplane and braced monoplane layouts. Traditionally the braced monoplane carries higher structural forces so the equivalent biplane weighs less. For a man-powered aircraft that is a hugely significant advantage. But, using modern materials, MacCready found that the weight difference was so small that the aerodynamic efficiency of the monoplane won the day.
Griffon Lionheart stagger wing composite with no struts first flew on 27 July 1997 Like the Beach stagger wing it used a R985. Only 3 made (Yellow company plane, white and blue) and production ended for kits 2001. Sounds like if more kits were made some tail changes were needed. Maybe some landing gear strengthening. "The owner/builder then applied left rudder, but the airplane continued to drift towards a runway sign. As they passed to the right of the sign the airplane pitched down violently, and nosed over. The airplane sustained substantial damage during the accident sequence to the left upper wing and the vertical stabilizer." Not sure if flaps down block tail action. "Probable Cause: The pilot's inadequate landing flare and subsequent loss of directional control during the landing roll."
$\begingroup$ Super Petrel LS Seaplane biplane Rotax engine model 912 is another composite. By Scoda Aeronautica in Brazil. $\endgroup$ Apr 30, 2020 at 15:18
$\begingroup$ Elytron 2S tiltrotor biplane / Prandtl wing box. Experimental work in progress. $\endgroup$ Apr 30, 2020 at 15:35
$\begingroup$ TVS-2DTS Honeywell TPE331-12U turboprop engine.Russian biplane to replace the AN-2 radial, AN-3 turboprop. Super nice plane. It is expected to fly at a maximum airspeed of 350 km/h and cover up to 4,500 km. The payload is calculated at 3.5 tons. $\endgroup$ Apr 30, 2020 at 15:40
1$\begingroup$ Welcome to Aviation! Please take the tour and read through the help center. You'll find that this is a Q&A board not a general discussion forum. Somehow, somewhere, there is an answer in what you've written, but it's pretty well buried in the somewhat rambling description of an accident (or 2?). If you'll edit to focus what you've written into an answer to the OPs question (perhaps incorporating your comments into the answer itself), I think you'll have a good answer that will garner some up votes. As it stands, this will likely get deleted for not answering the question. $\endgroup$– FreeManApr 30, 2020 at 16:14
There is one niche that may be of interest for commercial application, a very large cargo lifter biplane. Once wingspan reaches a certain length, even modern materials and designs reach limits due sheer size.
While 250 knots is considered extremely fast for a train, it is a long forgotten mode of travel for aircraft, with potentially enormous fuel savings. Coast to coast in the USA would be 10 hours of flight time. New York to Florida around 5 hours.
Combined with turboprops for regional next day cargo runs or mail, this could be a real money maker, with nostalgic appeal, and with safety in strength without the need for folding wings. Passengers could also ride low budget.
