I have been wondering how the mass flow rate is determined by the area of the engine air intake surface and the incoming speed of the air.
In still air, it is understandable that a stationary engine takes in air at the same rate as it is exhausting based on the preservation of the momentum of the air. Then, the mass flow rate through the engine intake surface can be easily calculated.
However, in still atmosphere with the same engine solely mounted to an aircraft cruising straight, level, and at constant speed $v$, it is not obvious to me how to determine the mass flow rate.
In particular, keeping the air intake surface area unity, can we determine the mass flow rate based on $v$ alone?
  • $\begingroup$ Yes, the mass flow rate is based on the intake area and air velocity. But if the engine is producing thrust, then the engine air velocity has to be higher than the freestream velocity. $\endgroup$
    – fooot
    Oct 8, 2015 at 16:54
  • $\begingroup$ @fooot, it has to be faster than the free stream in the nozzle, but not in the intake as evidenced by the fact that in supersonic flight the air still must reach the compressor face at subsonic speed. $\endgroup$
    Oct 8, 2015 at 17:05
  • $\begingroup$ @JanHudec good point, so not necessarily higher than freestream, but could definitely be different. $\endgroup$
    – fooot
    Oct 8, 2015 at 17:46
    $\begingroup$ @fooot, actually according to Peter it is almost constant. $\endgroup$
    Oct 8, 2015 at 19:23
  • $\begingroup$ @JanHudec well the pressure ratio changes between 0.84 and 1.37 assuming it equals 1 at M0.5... so the velocity is changing maybe +/-10%? $\endgroup$
    – fooot
    Oct 8, 2015 at 19:37
The short answer is: No. One cannot calculate the inlet mass-flow based on the velocity alone. However in order to "know" the velocity ( $v$ ) you most likely would have measured everything you need (see below).
Your confusion with regards to the in- and outlet mass-flow might be based on the fact that the intake does not "collect" all air upstream depending of the flight-velocity.
The key is not to think of the geometric area of the intake but the area of stream tube around the air entering the intake.
The velocity upstream of the intake is not equal to the air-speed (subsonic flight) because the potential field of the intake decelerates (or accelerates) the flow upstream of the intake and expands (or contracts) the stream tube (from Wikipedia):
Intake Stream Tubes
In order to calculate the mass-flow we need to determine the speed and the properties of the air.
(please observe that the air-speed ( $u$ ) at the intake is not equal the free-stream-spped ( $v$ ) )
Usually the measured properties are:
The following equations are used to calculate the mass-flow ( $\dot{m}$ ). Simplifications are commonly made for slow speeds unnecessarily excepting a 5% error. The following approach does not use these simplifications.
The equation which needs to be solved in the end is:
$\dot{m} = A \cdot \rho \cdot u$
Neglecting blockage effects and non-uniformities, the density ( $\rho$ ) and the velocity at the inlet ( $u$ ) are unknown and need to be derived from the measured values.
First the Mach-Number is calculated by solving the following equation (see Nasa) for the Mach-Number, $M$:
$\frac{p_\mathrm{s}}{p_\mathrm{t}} = \left( 1 + \frac{\gamma - 1}{2} M^2\right)^{\frac{\gamma}{\gamma-1}}$
Here $\gamma$ is the isentropic coefficient which is around $1.4$ for air depending on the humidity.
Second, with the Mach-Number, $M$, we can use another isentropic relation to calculate the static temperature, $T_\mathrm{s}$:
$\frac{T_\mathrm{s}}{T_\mathrm{t}} = \left( 1 + \frac{\gamma - 1}{2} M^2\right)^{-1}$
Third, using the ideal gas law the density ( $\rho$ ) can be calculated:
$\rho = \frac{p_\mathrm{s}}{RT_\mathrm{s}}$
Here $R$ is the Specific Gas Constant.
Forth, using the equation for speed of sound, $a$
$a = \sqrt{\gamma R T_\mathrm{s}}$
Finally Fifth, utilising the definition of the Mach-Number, $M$, the air-speed ( $u$ ) can be calculated:
$M = \frac{u}{a}$
Now all missing values are available to compute the mass-flow. This approach can easily expanded to cover humid air by adjusting $R$ and $\gamma$ with respect to the relative humidity.
As mentioned in other answers: The inlfuence of non-uniformity of the flow caused by boundary layers or inlet distortions (e.g. inlet-ducting) need to be corrected using a calibration.
You need pressure sensors, temperature sensors and flow speed sensors. All three together allow you to calculate the mass flow. Initially, this is done with arrays of sensors to find out about intake distortion and flow inhomogeneity. Once the intake has been calibrated, one discreet sensor of each type will do.
