17
Normally, it seems all the stealth designs dont use podded engines like others. Is this just to avoid the radar cross-section?
    $\begingroup$ Fighers generally don't use podded engines. A-10 is the only combat aircraft I can think of that has podded engines and it is not a(n air superiority) fighter. $\endgroup$
    Oct 5, 2015 at 12:48
26
Yes. From the PoV of stealth aircraft, the podded engine has significant disadvantages:
  • The engine pod has a high Radar Cross Section; In fact, stealth aircraft bury the engine inside their fuselages to minimize radar cross section. For example, the B2 Spirit engines were located inside the fuselage, as shown in the schematic below.
B-2 Engine schematic
  • The exposed compressor blades in the podded engine reflects radar waves, which is not good. For example, in Boeing X-32, the location of the engine meant that the compressor blades will be exposed to the Radar and baffles were (proposed to be) added to reduce the Radar cross section. On the other hand, it can be seen that it is practically impossible to see the F-22 compressor blades from any angle of the inlet.
F-22 intake
Source: f-16.net
  • In case of podded engine, it is difficult to shield the exhaust thermal signature. Compare the infrared signature of the typical airliner in the following picture with that of the B-2 Spirit in the next picture.
Civil aircraft Infrared
Source: laserfocusworld.com
B2 IRST
Source: bestfighter4canada.blogspot.in
Of course, contemporary combat aircraft don't use podded engines at all (with the exception of the A-10, which is a ground attack aircraft).
In addition to aeroalias's very detailed answer, I think a good point to start with this question is: "Why would any aircraft not use podded engines?".
There are a few advantages of having an engine in a separate pod, commonly it comes down to a simple lack of room in your fuselage. Either your thrust requirements would require too many or too large of engines to fit streamlined in a body that fulfills your other specifications. So, we see these on things with massive thrust requirements, which are almost exclusively cargo/transport or bomber aircraft. There are a few other bonuses too, like accessibility for maintenance or removing the sound and heat from the body of the aircraft.
Unfortunately, they also present massive, super-hot, and exposed targets. So for any combat aircraft that has the option, they will be onboard. The only combat aircraft I know of with podded engines, the A-10, has to push a very heavy airframe around with high mission loads. The main body is kept remarkably thin, thanks to the lack of internal weapon bays, so it makes more sense to mount these two large engines in pods then to grossly swell the body to fit them. It also gives more freedom in the placement and alignment of these engines, which are a bit particular for the A-10 given its unique lift and weight distribution.
There are additional reasons why you would avoid mounting these on a stealth aircraft, but for airframes like the F-22 or F-35, it wouldn't have made sense anyway. Large stealth aircraft like the SR-71 and B-2 are sleek enough that the requisite engines can fit rather comfortably within the design of the wing as well, so podding them would only hamper the design.
    $\begingroup$ Also, the air intake for supersonic aircraft needs to be relatively long, to reduce the airspeed to subsonic before it reaches the engine. It may contain internal moving parts, and/or use the geometry of the airframe ahead of the intake to control the position of the shock waves as the airflow slows down. A podded engine design would make those features impractically big and heavy. $\endgroup$
    – alephzero
    Oct 6, 2015 at 0:53
    $\begingroup$ Ease of maintenance would be the main reason for putting engines in pods, which is presumably why all modern jet airliners use that scheme $\endgroup$ Dec 27, 2015 at 17:38
The A-12's engines are podded partly for field replacement. The port and starboard engines are IDENTICAL (not symmetrical). That is to say, one of them is mounted upside down. As a result, they are interchangeable and can be field swapped. They built it so that if you have two A-12s stuck on the ground each with one bad engine, no matter which engine it is you can turn those into one A-12 with two good engines.
It was designed for grimdark WW3 with Russia in Eastern Europe. Its designers expected that it would be necessary to cobble damaged planes together at airstrips to continue the fight.
  • $\begingroup$ Welcome. Does it answer the question? It seems more useful as an (interesting) comment highlighting the A-12 as an exception to the rule, adding to @Jan Hudec 's one. $\endgroup$
    – mins
    Dec 27, 2015 at 16:11
