82
In the answer to this question it is noted that the B-52 takes off without rotating and climbs out in a nose-down attitude. Why was it designed this way?
    $\begingroup$ as far as i know the B52 makes use of ground effect and the setup of the undercarriage wont allow for rotation. if it did the pilot would have to (evan for a moment) be on one set of wheels $\endgroup$
    – chaos505
    Commented Oct 5, 2015 at 7:34
    $\begingroup$ @chaos505: is there an ELI5 on rotation? $\endgroup$
    – Firee
    Commented Oct 5, 2015 at 12:28
  • $\begingroup$ Take a look at this video, youtu.be/CCfJmuk-des Lots of B52s rotating at takeoff. Nosewheel comes off first, then first set of wheels, then second. Compare the takeoff to a B29 youtu.be/rcvDQXMh-DM. Pretty similar attitudes. So to say that they don’t rotate is wrong. Obviously, not the same as a C5 Galaxy youtu.be/eCC6ZbZvG8I but they have completely different missions. $\endgroup$
    – JScarry
    Commented Sep 10, 2018 at 22:54
    $\begingroup$ @JScarry Yeah, most of them do have a very slight bit of rotation, but nothing like you see in other aircraft. Check out this article from a pilot talking about how, instead of rotating, they "unstick." Basically they keep it as level as possible, but they don't want to wheelbarrow. I've seen some videos where there is no discernible rotation. Front and back leave the ground pretty much simultaneously. $\endgroup$
    – TomMcW
    Commented Sep 10, 2018 at 23:27
    $\begingroup$ @JScarry: The change in pitch attitude is from the climb path and not from increasing lift for liftoff. Basically, the airplane changes from horizontal acceleration to a combination of climb and acceleration, the climb causing it to change pitch attitude. No rotation to see here - just watch the elevators which don't move (which they would have to do in order to command a rotation). $\endgroup$ Commented Mar 11, 2019 at 20:22
7 Answers 7
86
The reason was to give the bombs the place close to the center of gravity.
Wing sweep (for high cruise Mach numbers) in combination with a high aspect ratio of the wing (for low induced drag) made it impossible to place the landing gear in the wing, so it had to be integrated into the fuselage. The main landing gear normally needs to be close to the center of gravity (slightly behind for a tricycle gear, slightly ahead for a taildragger), but this space was needed for the massive bomb bay. Since the bombs will be dropped somewhere along a bombing mission, dropping them should not upset the balance of the aircraft, so no compromise was possible.
B-52 cutaway drawing
B-52 cutaway drawing showing the two bomb bays in the center of the fuselage (picture source)
This problem existed already during the development of the 6-engined B-47 a few years before. In both designs, two pairs of landing gears were chosen, one pair ahead and one pair aft of the bomb bay, and the aircraft lost its ability to rotate for takeoff. Due to the powerful fowler flaps the attitude in cruise and at slow speed could be made identical. The downside is more drag during the take-off run, since the wing produces more lift, but this could be tolerated in a strategic bomber with air refueling capabilities.
B-47 on approach with drag chute deployed
B-47 on approach with gear down and drag chute deployed (picture source). Note the outriggers between the inner pair of engines - those were needed to keep the aircraft level on the ground.
B-52 in flight with gear down
B-52 in flight with gear down (picture source). Here the forward and aft gear of the B-47 have been replaced by pairs of gears to distribute the load over eight wheels and the outriggers are positioned outside of the outer engine pair, but the general gear configuration is fairly similar.
The Russian design bureau Myasishchyev found a different solution for their M-50 supersonic bomber in the mid-50s. They also had to put the bomb bay into the center fuselage and the main gear had to be placed so far aft that the M-50 could not be rotated the usual way with the elevator. To solve the problem, the engineers devised what they called the "galloping bicycle". When the aircraft reached 300 km/h, the forward gear rapidly extended to rotate it to 10°.
Myasishchyev M-50 with extended front gear strut
Myasishchyev M-50 with extended front gear strut (picture source). The two open doors under the cockpit were for the pilot and navigator: Their downward-ejecting seats would be lowered on cables for the crew to be strapped in at ground level, then winching themselves into place.
    $\begingroup$ When you say rotation are you talking in terms of pitch? $\endgroup$ Commented Oct 6, 2015 at 3:28
  • 10
    $\begingroup$ @DavidGrinberg: Yes. This is a fixed term describing the pitch motion from level to flight attitude during take-off. $\endgroup$ Commented Oct 6, 2015 at 5:26
    $\begingroup$ FYI, the B-52 only has one bomb bay. You might also mention the relatively high incidence angle. Further, the B-52 does rotate, just not to the level people are used to. $\endgroup$
    – OSUZorba
    Commented Dec 8, 2017 at 4:45
    $\begingroup$ @Sean: Yes, in theory a landing gear at that location would work. Only that for retraction it would need a large volume which the wing alone does not provide, so there would be a need for Tu-154-like pods. Next, the mass of such a landing gear on a high-wing plane would be prohibitive. The chosen solution is much lighter, and that it requires longer runways was considered acceptable. $\endgroup$ Commented Aug 18, 2020 at 5:13
    $\begingroup$ @SaxonXander You don't understand. The issue is the location of the wheels: The one o the U-2 is exactly where it is on most other airplanes: Right aft of the cg, so rotation needs only a little downforce on the tail. On the B-52 it is so far back that no amount of downforce would lift the nose gear off, ever. Only wing lift will do that, and to produce this lift the wing needs its incidence. Taking off without rotating is forced by the wheel location on the B-52. $\endgroup$ Commented Nov 27, 2021 at 5:55
57
Adding to the excellent Peter's answer who explained why for this particular model the wheels are placed far behind the centre of gravity (CG), I would like to clarify why this makes it impossible to rotate at take off.
A standard aircraft takes off right after the rotation, increasing the angle of attack and the lift. Before and while performing the rotation the lift produced by the wings is not enough to raise the position of the CG. Still, with the wheels placed right behind the CG, a small raise of the CG is required during the rotation. This is accomplished with the down force produced by the elevator and its big leverage.
If the wheels are moved backwards, then such lever becomes much less advantageous: the force produced by the tail on the CG is weaker, because the fulcrum is closer to it and farther from the CG. The maximum elevator down force and the structural strength can then make the rotation impossible.
The angle of attack of the wings of a B-52 is positive. The leading edge of the wing is higher than the trailing edge. So when you see the aircraft takeoff it seems to not rotate, but when the fuselage is level, the wings are at a positive angle of attack. When the B-52 is in level flight, the nose is down, you can not see the nose from the cockpit and it is like you are sitting on a cloud.
    $\begingroup$ Great answer that gets immediately to the crux of the issue - how it can takeoff without rotating very much at all. $\endgroup$
    – Penguin
    Commented Sep 11, 2018 at 10:48
  • $\begingroup$ Yes, but your terminology is off a little. AoA is regulated by the elevator. The angle of incidence is the angle of the airfoils chord to the fuselage. Most airliners have a 2° or 3° nose up angle of incidence. The B-52 has an 8° nose down angle of incidence. $\endgroup$ Commented Nov 26, 2021 at 19:24
  • $\begingroup$ @SaxonXander -- when you say "nose up", are you referring to the "nose" of the airfoil, or the actual nose of the plane? The normal terminology is to say that the wing has "positive incidence" if the mean chord line of the airfoil is higher in front, and lower in back, compared to longitudinal axis of the fuselage. By this terminology, the B-52 wing definitely has strongly positive incidence. I can't tell whether you are saying that (by this terminology) the wings of airliners would be said to have negative incidence, or just much less positive incidence than the wing of the B-52. $\endgroup$ Commented Jun 29, 2022 at 5:02
  • $\begingroup$ (The latter situation is the actual one.) $\endgroup$ Commented Jun 29, 2022 at 5:04
The B52 does "rotate" on takeoff just not to the degree of what seems normal for such a large jet.
All airplanes must produce lift that is greater than the opposing force of gravity/its weight for it to leave the runway. When lift = weight/gravity the airplane is in a stable state, which means the rate of climb or descent will be constant. This means unless the lift exceeds the weight an airplane will never leave the ground. Once in flight the airplane's rate of climb stabilizes, or becomes constant when lift = gravity/weight (the opposing force).
The answer is it only appears the B52 is not rotating. The pilots are applying "up" elevator and increasing the angle of attack of the wing, thus increasing lift.
I will throw a correction to an answer given above:
The CG, center of gravity, is fixed and unless a weight/load moves within the airplane it never changes. Examples of things which would change an airplanes CG are fuel burn off, bomb dropped, or a cargo shift.
When the elevator is moved the airplane "pitches" up, because the tail (horizontal) stabilizer is producing "negative" lift (it pushes down on the tail), and rotates the airplane along the CG. The placement of the landing gear actual opposes the rotation of the airplane in most designs. The change in "angle of attack" of the wing due to the pitching up increases the lift produced by the wing.
The placement of the landing gear is a compromise based on the design of the airplane. The B52 and its tandem wheel set is a compromise because of the wing and body design of the airplane.
Add one more thing to prevent confusion:
When an airplane "rotates" for takeoff the force (or weight) of the horizontal stabilizer must be greater than the weight of the airplane in front of the rear most wheels for the airplane to "pitch up."
Most (if not all) large transport type large airplanes the whole horizontal stabilizer (compared to just the elevator on smaller airplanes) is trimmed for take off to provide a "neutral" force for the desired takeoff speed. If the stabilizer trim is set incorrectly there may not be enough "elevator" to either pitch up or to prevent a spontaneous un-commanded pitch up of the airplane. Both are disastrous and the results of which can be found on youtube.
    $\begingroup$ Can you explain how when lift=gravity the a/c can be climbing? It seems to me if lift= gravity then you would not climb or descend, regardless of attitude. And actually, if you are nose-up the lift factor would tilt aft just a bit (depending on wing design) and lift would have to be greater than gravity to maintain the same altitude. $\endgroup$
    – TomMcW
    Commented Oct 6, 2015 at 15:36
    $\begingroup$ First to understand the basic of aerodynamics the wing doesn't care where it is pointed, it only knows the "relative" wind and angle of attack. The reason an airplane climbs when lift = gravity/weight is because it has more thrust than it needs to maintain a constant airspeed. The lift does move as the wing changes speed and or shape, this is known as the "center of pressure." As the angle of attack changes the center of pressure will move and that is a function of the design of the airfoil. $\endgroup$ Commented Oct 6, 2015 at 15:53
    $\begingroup$ On second thought, I think I get it. Due to inertia, if lift= gravity and thrust= drag then the vector of the aircraft will be unchanged, whether that be climbing or level or descending. Am I thinking right now? $\endgroup$
    – TomMcW
    Commented Oct 6, 2015 at 15:56
    $\begingroup$ Tom: Yes when all four forces are equal the airplane is in a constant state. This means in level flight the speed is constant, altitude does not change. In a climb or descent it means the rate of climb or descent is constant and the speed is also constant. Anytime one of the forces changes something else changes. $\endgroup$ Commented Oct 6, 2015 at 16:01
    $\begingroup$ Thanks for all the explanation. As for the B-52, watching this video if it rotates at all it is imperceptible. Both front and back gear appear to lift off at exactly the same time. It's hard to tell real precisely but after pausing and rewinding several times I can't find a place where front gear appear to be up and back gear on the ground, $\endgroup$
    – TomMcW
    Commented Oct 6, 2015 at 17:02
I may have missed it, but it seems none of the answers addresses the main issue: why it does not rotate and climbs out in a nose-down attitude?
All of this will be clearer if you remember that lift depends, mainly, on angle of attack and speed.
The main way for any conventional airplane to take-off (and land) without rotating in pitch is by making the angle of incidence of the wings (approximately the fixed angle with which the wing attaches to the fuselage) equal to the take-of angle of attack with the aircraft parked on the ground. This way when the B-52 reaches its design lift-off speed it will takeoff in the same parked attitude. AS it accelerates it has to reduce the angle of attack from max lift to climb lift, which is lower due to higher speed and the upwards help of the engines,so it has to pitch down. When it reaches its cruise speed, it needs a very small angle of attack for the same lift and, to reach it, the nose must be pitched down even more.
This increases the drag of the fuselage, tail etc.; but is part of the compromise made to avoid rotating on take-off (and landing).
At max speed the B-52 flies with the nose markedly down, which can be seen when it flies in formation with faster aircraft.
It must be noted that long-range aircraft normally set the wing's angle of incidence close to their optimum cruise speed angle of attack, which is very low compared to their max lift angle of attack. These angles all vary with weight, other non-standard design variables. The goal is to cruise with the fuselage aligned with the relative wind (from the front) to reduce drag.
BTW, glider pilots practically also do not rotate during take-offs and get their take-off lift from the speed of the tow plane.
I've never seen a source for this explanation; but this is the result of an analysis based on my experiences as an aircraft designer and pilot. Tried to make it a bit less complicated than it is, rigorously speaking..
  • $\begingroup$ But, don't most airliners also cruise at their max L/D speed? Just like the B-52, right? So if their wings are also set at on the fuselage at the optimal angle for such a situation, shouldn't they too be capable of no-rotation takeoffs? $\endgroup$ Commented Jun 8, 2020 at 4:42
  • $\begingroup$ Most airplanes designed for long cruise flights, have wings installed at cruise angle. This is a small AoA. Lift depends on AoA X Speed. Since lift during cruise has to be constant - so the plane flies horizontal - when you increase speed for cruise, you must reduce the AoA from the take-off high to the cruise low. With the the cruise angle you position the fuselage so that aligned exactly with the wind passing the aircraft to minimize drag. If all is kept constant, the aircraft gets lighter due to the burnt fuel, and the lift will make it climb. Airlines accept that. It has advantages $\endgroup$ Commented Jun 9, 2020 at 8:54
  • $\begingroup$ So why didn't they just make the front gear legs of the B-52 longer, so that fuselage sat a little nose-high on the ground, and could be totally horizontal in cruise? This would still permit no-rotation takeoffs--the angle-of-attack of the wing with all the wheels on the ground could be exactly the same as it is with the present situation, but the incidence angle between the wing and the fuselage could be much less, to optimize for cruising flight rather than takeoff. Might make a good new ASE question. PS didn't the B-47 fuselage sit nose-high on the ground, just as is being suggested here? $\endgroup$ Commented Jun 29, 2022 at 5:09
The angle of incidence on the B-52s wing is very steep, at 8° nose down. This is compared in this example to airliners, which have a 2° or 3° nose up angle of incidence. If left alone, when airspeed increases enough to lift the aircraft, the rear landing gear will lift off first. When I flew the simulator, (and I noticed this on subsequent flights) the tail of the airplane would sort of 'wiggle'. Aside from airspeed, this was an indication to apply elevator to bring the nose up. Most of the time, all 4 main gear lift of at the same time. Sometimes the forward gear would come up first (but not by a lot). But since the angle of incidence is so high, the aircraft wants to fly nose down, which is backward of 'normal' aircraft.
I thought I have witnessed - and a B-52 navigator (Maj, USAF) once told me - that the tail wheels actually come up off the ground first. Or at least will, if left alone with no control input, I forget exactly what he said. But basically unlike any other aircraft, the placement of the tandem gears and the super large horizontal tail allow for a lifting moment of the rear wheels off the ground before the fronts can be lifted off, if care is not taken.
  • $\begingroup$ Yes, you heard that correctly, but the reason is the angle of incidence of the wing, mostly. The giant horizontal stab certainly helps. $\endgroup$ Commented Nov 26, 2021 at 5:43
