In a flight database that I'm working with on a project, there is a column of data called "flightCategory" with values "C", "G", "T", etc. Any idea what those actually mean? From what I understand, the database is from FAA. But I'm not 100% sure.
  • 8
    $\begingroup$ What is the database and what other columns are there? The context could help us. What are the rest of the values? Can you post the database? $\endgroup$
    – Lnafziger
    Mar 11, 2014 at 0:27
    $\begingroup$ Grasping at straws, I'm going to guess flight plan, and type of flight, 'G' being general aviation, 'C' I think used to be commercial, being replaced by 'S' for scheduled and 'N' for non-scheduled. But I'm not a flight plan connoisseur so I might be off the mark. Still leaves 'T' though. $\endgroup$
    – falstro
    Mar 11, 2014 at 10:49
I got the answer. 'C' is commercial, 'G' general aviation, 'T' taxi, etc.
Update:
http://www.faa.gov/air_traffic/publications/atpubs/fss/AppendixA.htm, under section "Type of flight", it lists
S if scheduled air service
N if non­scheduled air transport operation
G if general aviation
M if military
X if other than any of the defined categories above.
But types C and T isn't there.
    $\begingroup$ Without context it's hard to determine if this answer is useful (at least "useful to anyone who isn't you") -- can you tell us more about the database you're working with? $\endgroup$
    – voretaq7
    Mar 11, 2014 at 20:54
  • $\begingroup$ Initially I only know these abbreviated codes "C", "G", etc. and nothing else. Later I was told what they actually mean. The relevant engineer dug the information up from comments in source code. $\endgroup$
    – Meng Lu
    Mar 13, 2014 at 16:33
    $\begingroup$ You're missing the point of context - What database is this out of?, Who created/maintains it? etc. - without that context this question and answer aren't useful to the general public. $\endgroup$
    – voretaq7
    Mar 13, 2014 at 17:04
  • $\begingroup$ That, honestly, I don't know. The only thing I've been let know is the data is from FAA. $\endgroup$
    – Meng Lu
    Mar 14, 2014 at 4:25
  • $\begingroup$ and where would you have found it? how does it look like? how is it named? $\endgroup$
    – Federico
    Aug 19, 2014 at 6:13
