10
You see a lot of experimental canard GA aircraft, and their performance characteristics seem great. Why don't we see any production canard designs?
EDIT
For clarification. I'm asking about small airplanes, competitors to the Cessna 172 or Piper Archer in size. I'm also asking about airplanes that you can purchase from a manufacturer, like the above aircraft. An example of a company attempting to eventually make a small canard style production GA aircraft is Raptor Aircraft
    $\begingroup$ A brief Google search reveals many production canard designs. $\endgroup$
    – Simon
    Sep 28, 2015 at 18:50
  • $\begingroup$ @Simon, those are not production GA aircraft ... $\endgroup$
    – Arel
    Sep 28, 2015 at 19:20
  • $\begingroup$ @Simon, After looking at several of those pictures, I could not find a single result that was a production GA aircraft. $\endgroup$
    – Arel
    Sep 28, 2015 at 19:24
    $\begingroup$ When you say "production", are you excluding kits? $\endgroup$
    – Simon
    Sep 28, 2015 at 19:28
    $\begingroup$ @Arel NP. Just a question of terminology. Kits are production to me...cheers $\endgroup$
    – Simon
    Sep 28, 2015 at 20:00
14
Why would you fly with a deployed spoiler when you can have a clean aircraft? Sure, there are many canard kit plane designs, but when you look closer at their performance, its is not improved by the location of the elevator. Burt Rutan would always choose a higher wing loading than required to fulfill the FAR part 23 requirements for low speed, so his designs could cruise faster. When asked about this, his usual response was "**ck the FAA!".
When you look closely, canards will give you:
  • With natural pitch stability a higher lift coefficient on the forward wing which also needs to have some margin for control surface deflections. Consequently, the big, rear wing is operating at a fraction of its potential when the aircraft stalls.
  • The vorticity from the front wing creates a downwash at the mid section of the rear wing and an upwash at the outer sections. The strength of these induced speeds varies with speed, so the main wing can produce an elliptic circulation at only one angle of attack. At other angles, its induced drag is higher than what is possible with a conventional configuration.
  • The center of gravity is ahead of the main wing, so the landing gear needs to retract into the fuselage, taking space away from the cockpit. To move the wing center section forward, so it can accommodate the landing gear, the wing needs to be swept (which creates a host of problems of its own).
  • There is no good position to put a vertical surface, so again sweep is used to shift some part of the airframe backwards and combine the vertical with winglets. Those need to point upwards, so they do not hit the ground during take-off and landing when the better winglet would point downwards.
Canards start to make sense when they are unstable, but this is not a good approach for a GA aircraft.
The Piaggio P-180 is a GA aircraft with a canard.
    $\begingroup$ It has a canard AND a horizontal stabilizer. Without the latter, it was rather unstable in flight. And the 180 is not fly-by-wire. $\endgroup$
    – Meower68
    Jun 26, 2019 at 18:08
